Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
anyone - got my relay & trial and error fitting does NOT appeal to me! 2001 TD5 110 DCPU in Bonatti Grey
12th Jan 2011 3:06pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Any vw dealer should stock it caror comercial they are fitted to the transporter T4 hope that helps |
12th Jan 2011 6:48pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Afternoon all,
I've just done this courtesy of eBay (with a bit of a false start) and it works perfectly! I bought the Audi part first (321 955 531 A) and it didn't work. In fact it functioned exactly the same as the original. So I bought the VW part (357 955 531) and it works great. This place is a really useful source of information. Pete |
13th Jan 2011 4:45pm |
Anyone else doing this, who is an electrical numbskull like myself, should look for Lucas relay AMR2341 on a TD5 - behind the instrument cluser on the right hand side.
New relay clever little upgrade - like the 3 wipes only on wash cycle. 2001 TD5 110 DCPU in Bonatti Grey |
16th Jan 2011 8:03pm |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 |
Just got a couple of these, out of a VW Polo from a breaker for £14 yet they look like new.
At less than a minute, this has to be the quickest and easiest, yet worthwhile mod I've done Just got to sort out the back one now but decided it's too cold to be faffing around outside today MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
29th Jan 2011 1:06pm |
crasha Member Since: 12 Jun 2011 Location: Wiltshire Posts: 15 |
To confirm this is indeed the best mod in the least possible time, just get yourself a new relay and swap over.
Driver adjusted front intermittent wiper is now working perfectly. Now for the rear... which involves more wiring. |
8th Dec 2011 1:46pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
does it work and the rear wper aswell.....although i haven't used it yet!
8th Dec 2011 3:52pm |
Search for +rear +wiper and you will find the thread, the front is a pure relay swap the rear requires an additional relay plus some wiring. In a Puma the front really is get a new relay and swap over and hey presto.
8th Dec 2011 3:55pm |
I know it's bad form to drag up old posts but I was amused to get an email from mm4x4 pushing their latest products................they are selling these same relays, Hella branded for £16+VAT http://www.mm-4x4.com/defender-200tdi--300...4212-p.asp At least you can get one from them if you haven't done the mod yet knowing that you have got some gaureentee
15th Apr 2012 12:33am |
That's not a bad price for a new one. ISTR the VW one was around £40, although obviously a lot cheaper on eBay. Darren
15th Apr 2012 9:29am |
nihwrd Member Since: 12 Apr 2012 Location: Somerset Posts: 28 |
Genius mod. Cheap, simple, quick and properly useful.
Thanks to all on here for posting, just need to try the rear one at the weekend! Nick |
9th May 2012 8:28pm |
Ravers Member Since: 22 Feb 2012 Location: Germany Posts: 19 |
Just ordered mine off flea bay, then will fix the rear wiper to intermittent.
top mod, thanks Ravers |
14th May 2012 9:20pm |
Just completed this mod. Really plug and play, however.....
First bought on ebay a Hella "wiper relay programmable", part #AMR2341DELAY or 5WG 003 620-08 Does not work Then called my VW dealer and asked for the first VW relay code posted by dgardel which also show in his pictures of this VW relay (357 955 531) VW dealer told me that this code is obsolete now, and was replaced by a new VW parts code (2nd one mentioned by dgardel). I have added 2 pictures of this new relay here for those who would still like to make this mod so that they can immediately order the correct current part nbr. Most important, it works a treat , tried several interval times between 1 and 25 seconds, and it does exactly that Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
27th Aug 2012 5:07pm |
Eric ... not sure if this will help but I picked my relay up in Lausanne, there is a huge VW/Audi/Sko-sh!te warehouse / dealership, but like most things in CH, you pay top-dollar - probably best to ebay it
27th Aug 2012 5:12pm |
