![]() | Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence |
Fatto!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
[quote="Ads90"]Thanks for posting that - I would like to do the rear wiper mod, but sounds like it's the instructions for connecting to the pre-2002 rear wiper knob, but presumably it will work on the later push/push button?
Anyone know the connections, or if there is a relay that can be swapped (like the front wiper mod)?[/quote] Hi guys, just a quick "up" for this thread: anyone has managed to make intermittent the rear wiper of a Td5 or a Puma using the spare relay after the replacement with the VW one? The instuctions in the pdf file are clearly for the pre-2002. From the wiring diagram of the Td5, there should be a relay so most likely just replacing it with the spare one should do the trick (proven that the connections feed the correct contacts on therelay)... problem is that i have no idea of where to go an look for the relay ![]() Thanks for your time ![]() |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 ![]() ![]() |
I know this is a Puma specific catagory, but I have just obtained one of these wiper relays for use in a TD5 Defender, and it does not appear to work correctly. Everything works as described EXCEPT that if one pushes in the stalk to wash the windscreen the wipers remain on, instead of turning off after 3 wipes. The only way to turn the wipers off is to turn off the ignition. After this, the only thing that will work is constant wipers at low or high speed. After leaving everything off for a few minutes, the intermittent will work again, but with the same problem as described. I think I probably have a faulty relay (just my luck!), but I would like to hear from any TD5 owners who have used these relays successfully, just to ascertain this before I return it. Any information would be appreciated. Cheers, Lionel |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Works just fine on mine. Suspect you have a duff relay... Dave
Green Goddess - 1998 Defender 110 300tdi |
![]() Green Goddess - 1998 Defender 110 300tdi |
BarneyRubble Member Since: 08 Mar 2010 Location: Naphill Posts: 103 ![]() ![]() ![]() |
Just been quoted £55 each from my local Bosch retailer, and told none in UK stock.
![]() I don't like ebay, so any suggestions where else to get them? Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Quite a few on ebay - look for the 99 in the picture.... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Relay arrived today and works as described. Found it on eBay USA. $18 inc postage to UK. Still 2 left from this supplier if anyone interested : [url] http://cgi.ebay.com/ebaymotors/ws/eBayISAP...3574[/url]
Amos Member Since: 10 Oct 2010 Location: Northern Ireland Posts: 38 ![]() ![]() ![]() |
Anyone got a link, to were they bought there's......?
Got mine from ebay in the end - search for the VW code 357 955 531 - £12 ish + £2.50 postage.
Works great. Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
Got a Bosch one new...! Cheers
Just need my 90 to arrive now, lol...! |
60North110 Member Since: 11 Oct 2010 Location: Shetland Posts: 13 ![]() ![]() |
Just got one off ebay, fitted today
![]() Brilliant ! Now can the Rear Wipe be made intermittent wipe too ? ![]() |
Mine arrived this morning (the VW 99 relay) and it was fitted within 5 minutes!
In terms of bank-per-buck, this has to be one of the best mods you can do to a Landy. Mine is fitted to a TD5, in case additional confirmation of suitability is required. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Have just modified the rear wiper to get variable intermit.
Easy mod - move 2 wires, add a 12v and ground connection and fit one link. Biggest hassle is getting the connectors out of the existing relay base. I'll post the wiring diagram when I have corrected it. ![]() Click image to enlarge ![]() Click image to enlarge Works like the front - press the switch, let it wipe, switch it off, wait until you want it to wipe again, switch it on, and leave it - the wipers operate on intermit at the time you left between switching off and back on again. Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
