Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence
Page 5 of 8 <12345678>
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
anyone - got my relay & trial and error fitting does NOT appeal to me! 2001 TD5 110 DCPU in Bonatti Grey
Post #52554 12th Jan 2011 3:06pm
According to the workshop manual its behind the speedometer so you'll need to pop the instrument cluster out. Looks to me to be the middle relay. You could switch the wipers on and feel which one clicks ?
Post #52568 12th Jan 2011 4:44pm
mick
Re: WW variable intermitance
Andrea wrote:
Hi there..
How do i get this in South Africa? Is it possible?
Ragards.
Any vw dealer should stock it caror comercial they are fitted to the transporter T4 hope that helps
Post #52587 12th Jan 2011 6:48pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Afternoon all,
I've just done this courtesy of eBay (with a bit of a false start) and it works perfectly!
I bought the Audi part first (321 955 531 A) and it didn't work. In fact it functioned exactly the same as the original. So I bought the VW part (357 955 531) and it works great.
This place is a really useful source of information.
Pete
Post #52788 13th Jan 2011 4:45pm
daviec1
Anyone else doing this, who is an electrical numbskull like myself, should look for Lucas relay AMR2341 on a TD5 - behind the instrument cluser on the right hand side.
New relay clever little upgrade - like the 3 wipes only on wash cycle. 2001 TD5 110 DCPU in Bonatti Grey
Post #53334 16th Jan 2011 8:03pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Just got a couple of these, out of a VW Polo from a breaker for £14 yet they look like new.
At less than a minute, this has to be the quickest and easiest, yet worthwhile mod I've done Mr. Green
Just got to sort out the back one now but decided it's too cold to be faffing around outside today Wink MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #55599 29th Jan 2011 1:06pm
crasha
To confirm this is indeed the best mod in the least possible time, just get yourself a new relay and swap over.
Driver adjusted front intermittent wiper is now working perfectly.
Now for the rear... which involves more wiring.
Post #105515 8th Dec 2011 1:46pm
T1G UP
does it work and the rear wper aswell.....although i haven't used it yet!
Post #105533 8th Dec 2011 3:52pm
crasha
Search for +rear +wiper and you will find the thread, the front is a pure relay swap the rear requires an additional relay plus some wiring. In a Puma the front really is get a new relay and swap over and hey presto.
Post #105534 8th Dec 2011 3:55pm
JWL
I know it's bad form to drag up old posts but I was amused to get an email from mm4x4 pushing their latest products................they are selling these same relays, Hella branded for £16+VAT http://www.mm-4x4.com/defender-200tdi--300...4212-p.asp At least you can get one from them if you haven't done the mod yet knowing that you have got some gaureentee Thumbs Up
Post #139311 15th Apr 2012 12:33am
That's not a bad price for a new one. ISTR the VW one was around £40, although obviously a lot cheaper on eBay. Darren
Post #139323 15th Apr 2012 9:29am
nihwrd
Genius mod. Cheap, simple, quick and properly useful.
Thanks to all on here for posting, just need to try the rear one at the weekend!
Nick
Post #144216 9th May 2012 8:28pm
Ravers
Just ordered mine off flea bay, then will fix the rear wiper to intermittent.
top mod, thanks Ravers
Post #144997 14th May 2012 9:20pm
ericvv
Just completed this mod. Really plug and play, however.....
First bought on ebay a Hella "wiper relay programmable", part #AMR2341DELAY or 5WG 003 620-08
Does not work Sad
Then called my VW dealer and asked for the first VW relay code posted by dgardel which also show in his pictures of this VW relay (357 955 531)
VW dealer told me that this code is obsolete now, and was replaced by a new VW parts code (2nd one mentioned by dgardel).
I have added 2 pictures of this new relay here for those who would still like to make this mod so that they can immediately order the correct current part nbr.
Most important, it works a treat Thumbs Up , tried several interval times between 1 and 25 seconds, and it does exactly that Thumbs Up
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #164736 27th Aug 2012 5:07pm
Eric ... not sure if this will help but I picked my relay up in Lausanne, there is a huge VW/Audi/Sko-sh!te warehouse / dealership, but like most things in CH, you pay top-dollar - probably best to ebay it
Post #164737 27th Aug 2012 5:12pm
