Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence
Page 1 of 8 12345678>
dgardel
Italy
With A REAL PLUG & PLAY solution....
buy this click for ebay
Volskwagen code: 357 955 531 or 3B0 955 531
Bosch code: 0 986 335 058
Beru code: 0 900 301 082
To program is easy:
Push down on the w-w lever, have it wipe once, bring it up and wait until you need to wipe again,
then push it down.
It'll use the same wait interval! Very clever, but not obvious.
more info and more spare parts code here Selec wiki
Happy to improve our Puma
Post #15515 15th Sep 2009 11:13pm
110SEB
How easy was fitting. What does the stalk now do? Down being intermittent, Middle off, Up 1 constant and Up 2 fast.
Post #15518 15th Sep 2009 11:23pm
dgardel
Italy
Down being intermittent yes but with fixed time interval.
with this relay you can change the intermittent time interval duration Thumbs Up Thumbs Up Thumbs Up
Post #15520 15th Sep 2009 11:31pm
dgardel
Italy
Its works in this way:
1. light rain put DOWN the WW lever and then up (off)
2. wait XX seconds
3. put DOWN again the WW lever
from now the WW start automatically EVERY XX seconds.
When you switch off again the WW the system resets itself at 6 seconds.
and again
1. After a short spray of the screen there is only 1 wipe in stead of 4.
2. After a longer spray of the screen there is only 3 wipes in stead of 4.
Post #15521 15th Sep 2009 11:36pm
dgardel
Italy
p.s. payed 9.99 USD on ebay (plus 7 USD of postage cost) Whistle
Post #15522 15th Sep 2009 11:36pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
SO its just a matter of swapping over the intermittent relay then?????
In that case I'll order one when I get home from holidays. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #15529 16th Sep 2009 6:59am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Good find nice one Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #15530 16th Sep 2009 8:23am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Great mod i shall get one ready for the rainy season Thumbs Up
Post #15532 16th Sep 2009 9:24am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Will this work on a TD5 too? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #15534 16th Sep 2009 9:56am
Anvil
Italy 2008 Defender 90 Puma 2.4 CSW Tonga Green
I was wondering this morning about adjustable delay. I'll definitely check it out
Thumbs Up
Post #15536 16th Sep 2009 10:32am
dm_td5
Never mind about a Td5... will it also work on a Tdi? 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #15538 16th Sep 2009 12:42pm
dgardel
Italy
Yes!!!
Post #15539 16th Sep 2009 12:47pm
dgardel
Italy
I don't know on Tdi but check the installed intermittence, if it has the same P/N of Td5 and Puma you can do it.
it's a red relay case box on the fusible bay under the steering wheel.
This late evening I'll check the P/N of my original intermittence (I'm in office now) and I'll write here.
Post #15540 16th Sep 2009 12:48pm
dgardel
Italy
Yes!!!
Post #15541 16th Sep 2009 12:49pm
roel
Thanks,
I will get one too then. Roel
Post #15542 16th Sep 2009 1:05pm
