Home > My Defender > What Did You Do In Your Defender Today |
For the summer replaced my yellow fogs by white fogs. The very same Hella Comet 550.
Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
5th May 2016 4:14pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5853 |
Fitted the rear MudStuff speaker mounts ready for a set of 130mm speakers - when I buy a set.
Started adding some foam insulation around the rear windows and also added some behind the speaker pods. Need some contact adhesive next to stick the foam to the metal work. Got the winch back from Goodwinch after a service. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
6th May 2016 4:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20460 |
Just drove it after lots of new parts fitted, everything seating in now.
More than enough work has been done on it lately! |
6th May 2016 5:05pm |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
Clocked 100k!
('53 TD5) |
7th May 2016 7:12pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Fitted one of them dog guard thingies that goes between the 'boot' and the back of the seats to keep pooch safe.
What a palava, all caused by the totally crap instructions which were all in picture form without any words at all. It took me about three hours (gauged by the radio turning itself off twice) which is about two hours longer than it would have taken if they put words in the instructions. Anyway, it's done. Next task is to build a box to level out the wheel arches and create a space to hide all the crap I lug around for no reason. |
7th May 2016 7:25pm |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 412 |
Click image to enlarge Pumped it up Click image to enlarge |
7th May 2016 8:08pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1972 |
I used the old one to chase two cars of yoofs off the farm. Its funny how a slightly careworn pick up says 'don't argue'! Tomorrow I will mostly be spraying ACF-50 on the Heritage as per the corrosion prevention sticky, hopefully without interruptions...
7th May 2016 8:16pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2217 |
Finally got the LWT back on the road after winter refurb and new cylinder head . MOT'd and running sweet .
7th May 2016 8:20pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1645 |
Is that HF? YOLO... You Only Live Once... |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 378 |
Went from this
Click image to enlarge To this. 2002 td5 90 county hardtop |
7th May 2016 8:55pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3760 |
^ interested to see the final finish,
Fed up of mine looking a mess, what products did you use. Thanks |
7th May 2016 9:05pm |
I sanded it all over, then I treated the rust with Bilt Hamber hydrate 80.
What you see at the end is just 2 coats of halfords primer. It takes 24 hrs to dry properly, so I will spray it black tomorrow. I've got Matt black, but I'm not sure wether to spray it satin black instead. When it's all finished I'm going to spray some Bilt Hamber dynax-UC over it. It's a thin clear film that's supposed to protect the paint and metal. It's worth a try anyway! 2002 td5 90 county hardtop |
7th May 2016 9:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17457 |
Someone's stolen the bottom of your towbar! |
7th May 2016 9:38pm |
It kept dragging on the ground when it took the defender off road. So I took it into work and cut it off. The tow ball still goes low enough when I use it occasionally. 2002 td5 90 county hardtop
7th May 2016 9:45pm |
