Page 906 of 1379 <123 ... 905906907 ... 137713781379>
Good plan, thought that might be the back-story!
Post #529851 7th May 2016 9:56pm
@chopcat. That's making me look at Icom rigs now. Whistle
Post #529852 7th May 2016 9:57pm
mk1collector
Nearly killed my clutch, Rolling Eyes see here
http://www.defender2.net/forum/topic46263.html
All ideas welcome Thumbs Up Ray
My build thread
Post #529855 7th May 2016 10:01pm
Accidental post, deleted.
Post #529857 7th May 2016 10:01pm
Well this was not today but a few days ago, took me a couple of days to recover from the work involved. Rolling with laughter
Really pleased with these, new turret rings too.
However, the real work involved was changing springs.
So now I have, genuine new front and rear HT springs, genuine isolators top and bottom and rear wrap around isolators also.
New genuine Spring seats F&R inc fixings and retainer plates for the rear.
D44 turret rings, D44 turrets. (Turrets powder coated silver as standard, I etch primed then stonechiped - finally Dinitrol.)
New front shocks / dampers & the same rear inc genuine bushes and genuine steering damper bushes.
Completely back to genuine no Poly stuff.
It's taken me nearly a year to get all parts I needed for this down to nuts and bolts.
I am really happy with the ride quality and smoothness and glad I had the isolators as I had no lowering after changing to these from HD.
Very flexible and softer, much better articulation too due to not being so stiff.
Mr. Green
Post #529861 7th May 2016 10:19pm
LR90XS2011
went for a trundle around the Warwickshire country side just to enjoy the scenery and the rain, saw a bad crash with the emergency services in attendance between Lapworth and Knowle a front end flattened VW and a Transit sized van on it side (2 Ambulances in attendance suggesting some poor peoples lives have just altered).
When I got home I looked down at my scan gauge and it showed 39.5 mpg av !
Noted also a defender outside Lookers Solihull, will be passing later today so will get details and a photo or 2 if it is for sale.
Keith
love your LWT Bow down DEFENDER 90 TDCI XS,
Post #529879 8th May 2016 5:48am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Please can you advise what HT springs are?
Post #529898 8th May 2016 7:56am
bm52
Custom
Can I also ask which springs and dampers you used
Post #529899 8th May 2016 7:59am
bm52 - HT springs are springs for the Hard Top Defender, the springs I got were new take off from CSK.
The Dampers, again new take of and all items are Genuine parts.
Hope that helps. Thumbs Up
P.S. If your running factory springs, Spring isolators will give you a minor life all around, if your running Heavy duty springs like mine was it should be about the same.
Think mine now is every so slightly higher at the rear and a little lower at the front but exactly as a Factory HT would be only a touch lifted due to the isolators.
The turret rings also do but about 5mm Rolling with laughter
Post #529928 8th May 2016 11:11am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Crossmember all finished!
underneath the car is all rust proofed and sealed.
Just the rest of the car to go, but all summer to do it! 2002 td5 90 county hardtop
Post #529954 8th May 2016 3:28pm
Looking good! DIY underseal is a big undertaking work and time wise and very very dirty.
Post #529970 8th May 2016 4:30pm
jaygti
It really was unpleasant.
I originally spent about half an hour and gave up.
I then ordered some disposable boiler suits of eBay. 5 for £10.
It was much better being completely covered.
It's a whole weekends work if you prepare all the metal properly.
Still it only cost about £120 total so it was a big saving.
And I'm really pleased even though no one can see it! 2002 td5 90 county hardtop
Post #529977 8th May 2016 5:19pm
Yes, that's the thing DIY your as good as paid yourself and you know for certain the job is done properly.
Post #529980 8th May 2016 5:31pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Ok, not a Defender but we had a little trundle over the downs in the 80"
Can't beat it with the roof off and screen down Thumbs Up
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #529996 8th May 2016 7:24pm
excossack
Re-fitted the winch after being serviced by Goodwinch - Sounds much better than before. Thumbs Up 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #529997 8th May 2016 7:31pm
