Home > My Defender > What Did You Do In Your Defender Today |
Few steps closer to sorting my Sankey camping setup. I used to use an old caravan awning hung off the side of my 110
Click image to enlarge Now I have my Sankey plus a top I can attach it to that and have my motor mobile. A couple of sheets of marine ply later and I have this. Click image to enlarge All the panels fix to the trailer and when travelling can be strapped to the roofrack on the trailer. Whilst I'm waiting for the awning rail the boy and I blobbed some paint on, you can just see the two other panels on the roofrack in their storage position. Click image to enlarge I don't want to tie up the trailer in just a camping mode as it's too useful for other purposes. Future ideas are a hatch in the side to allow access from under the awning for cooking/storage etc, I will put a ply platform inside the trailer on top of the wheel arches and use that for sleeping on with storage underneath, line the Ifor conopy with insulating foam and have a box for a leisure battery with charging via a 12N socket off the tow vehicle and have an inverter and perhaps an electric hook up thingy like on a caravan. |
10th Apr 2016 4:39pm |
Arran73 Member Since: 25 Mar 2013 Location: Commugny, Switzerland Posts: 133 |
Forgot I could not back into my carport
Click image to enlarge 1997 Defender 90 300tdi |
10th Apr 2016 4:45pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
just remember defenders look better with battle scars. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
10th Apr 2016 4:57pm |
7heaven Member Since: 03 Feb 2016 Location: Oxfordshire Posts: 122 |
2020 110 D200 Base - Pangea with satin paint protection 2015 90 XS Station Wagon (sold) 2010 110 XS Station Wagon (stolen) |
True that, but will try to fix it the best I can non the less, then stick a ladder and work light there and hay presto 1997 Defender 90 300tdi |
10th Apr 2016 5:00pm |
Oops, that's not good. Guess you will need to plan a little trip to Gland soon... Hope you get it sorted without costing an arm and a leg. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
10th Apr 2016 5:13pm |
Eric, will try to fix it myself, Gland would cost a fortune that said he has a black roof lying around but not sure I want to play around with removing the roof. 1997 Defender 90 300tdi
10th Apr 2016 5:19pm |
Talk to bob at freddy marine, he has lots of contacts
10th Apr 2016 5:21pm |
Took the disco 1 out for a run on the plains again, really need to get the MUDs fitted
Loving the disco, the 300 tdi is "boss"! |
10th Apr 2016 5:22pm |
10th Apr 2016 5:31pm |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Your land rover may leak! |
10th Apr 2016 5:40pm |
Strip the headlining out then Cut a block of wood to fit to the inner curve of the back of the roof then put the wood in place inside and hit the wood carefully with a sledge hammer until it all looks reasonably in the right place. Then seal where appropriate Ray My build thread http://www.defender2.net/forum/topic17615.html |
10th Apr 2016 6:09pm |
Great thanks for the tip, will give that a go next weekend, at the moment it does not seem to have a water leak issue, will see when I smake it back into shape 1997 Defender 90 300tdi
10th Apr 2016 6:49pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
Just got back from a weekend in Devon using the old girl as a family bus. Forgot about the hills they have down they but she did good as always. Sorry no pictures I got blown over and soaked trying to take any. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
11th Apr 2016 2:53pm |
