Page 899 of 1378 <123 ... 898899900 ... 137613771378>
JWL
Few steps closer to sorting my Sankey camping setup. I used to use an old caravan awning hung off the side of my 110
Now I have my Sankey plus a top I can attach it to that and have my motor mobile. A couple of sheets of marine ply later and I have this.
All the panels fix to the trailer and when travelling can be strapped to the roofrack on the trailer.
Whilst I'm waiting for the awning rail the boy and I blobbed some paint on, you can just see the two other panels on the roofrack in their storage position.
I don't want to tie up the trailer in just a camping mode as it's too useful for other purposes.
Future ideas are a hatch in the side to allow access from under the awning for cooking/storage etc, I will put a ply platform inside the trailer on top of the wheel arches and use that for sleeping on with storage underneath, line the Ifor conopy with insulating foam and have a box for a leisure battery with charging via a 12N socket off the tow vehicle and have an inverter and perhaps an electric hook up thingy like on a caravan.
Post #522796 10th Apr 2016 4:39pm
Arran73
Forgot I could not back into my carport Mad
 1997 Defender 90 300tdi
Post #522804 10th Apr 2016 4:45pm
7heaven
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Vacuum, wash and polish. Went to get fuel, took the long route home
 2020 110 D200 Base - Pangea with satin paint protection
2015 90 XS Station Wagon (sold)
2010 110 XS Station Wagon (stolen)
Post #522811 10th Apr 2016 4:57pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Shocked just remember defenders look better with battle scars. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #522813 10th Apr 2016 4:57pm
7heaven
Censored Crying or Very sad 2020 110 D200 Base - Pangea with satin paint protection
Post #522814 10th Apr 2016 4:57pm
Arran73
True that, but will try to fix it the best I can non the less, then stick a ladder and work light there and hay presto 1997 Defender 90 300tdi
Post #522816 10th Apr 2016 5:00pm
ericvv
Oops, that's not good. Sad Guess you will need to plan a little trip to Gland soon... Hope you get it sorted without costing an arm and a leg. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #522819 10th Apr 2016 5:13pm
Arran73
Eric, will try to fix it myself, Gland would cost a fortune that said he has a black roof lying around but not sure I want to play around with removing the roof. 1997 Defender 90 300tdi
Post #522822 10th Apr 2016 5:19pm
Talk to bob at freddy marine, he has lots of contacts
Post #522823 10th Apr 2016 5:21pm
Took the disco 1 out for a run on the plains again, really need to get the MUDs fitted
Loving the disco, the 300 tdi is "boss"!
Post #522824 10th Apr 2016 5:22pm
Arran73
Thumbs Up 1997 Defender 90 300tdi
Post #522826 10th Apr 2016 5:31pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Your land rover may leak!
Post #522830 10th Apr 2016 5:40pm
mk1collector
Strip the headlining out then Cut a block of wood to fit to the inner curve of the back of the roof then put the wood in place inside and hit the wood carefully with a sledge hammer until it all looks reasonably in the right place. Then seal where appropriate Mr. Green Ray
My build thread
Post #522838 10th Apr 2016 6:09pm
Arran73
Great thanks for the tip, will give that a go next weekend, at the moment it does not seem to have a water leak issue, will see when I smake it back into shape 1997 Defender 90 300tdi
Post #522865 10th Apr 2016 6:49pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Just got back from a weekend in Devon using the old girl as a family bus. Forgot about the hills they have down they but she did good as always. Sorry no pictures I got blown over and soaked trying to take any. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #523074 11th Apr 2016 2:53pm
