Page 898 of 1383 <123 ... 897898899 ... 138113821383>
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
After full service last week, changed turbo hose. Bottom water hose adjust fan belt and fitted roof bars for work.
Post #521160 5th Apr 2016 2:22pm
Swac3
Stuck a full width load bed mat in the back to cover the wheel boxes and a genuine LR dog guard into the Ht. 3 Landrovers
Post #521209 5th Apr 2016 4:31pm
steventheplumber
Did it fit well? Have you got a picture?
Post #521657 6th Apr 2016 7:30pm
Swac3
The mat or the dog guard? Can post a pic sure no problem 3 Landrovers
Post #521724 6th Apr 2016 9:06pm
steventheplumber
The mat, but what the hell the dog guard as well.
Post #521729 6th Apr 2016 9:09pm
srod
Went up the hill for more wood.
Got this trailer a couple of weeks ago, total impulse buy, thought at the time that i didn't really need it and what the hell was i doing buying it. Have used it just about every day since!
Post #521737 6th Apr 2016 9:24pm
Swac3
Mat needs sticking down at the sides maybe, planning to use that double sided tape carpet fitters use 3 Landrovers
Post #521742 6th Apr 2016 9:30pm
steventheplumber
That looks great, try some high temp spray glue won't move around in our hot summer!
To many tools etc. To see the bottom of my 90!
Proper job though looks good
Post #521744 6th Apr 2016 9:36pm
Fitted a set of new take off boosts and conti's ... Got a euro trip coming up Thumbs Up
Billberried the SVX alloys, that stuff is good!
I managed to get some new nano wax from BMW - I can confirm it works on land rovers too Thumbs Up
Post #522517 9th Apr 2016 4:43pm
Retroanaconda
Simple outrigger replacement turned into a much bigger job, much happy time with grinder/welder today.
Post #522568 9th Apr 2016 7:28pm
L110CDL
Went out today to do a recce on some green lanes, all worked ok and got home in one piece Thumbs Up Clayton.
Keeper.
Post #522600 9th Apr 2016 9:15pm
ericvv
Billberried.... That must mean..... euuhh? Confused
Translation for a non native English speaker please? Wink
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #522652 10th Apr 2016 5:02am
Eric - it's the name of the alloy wheel cleaning liquid I use, Billberry. Spray on, wait 5 mins, wash off and they look like new
http://www.theultimatefinish.co.uk/valet-p...Gwodkn0A8A
Post #522659 10th Apr 2016 6:46am
ericvv
Post #522668 10th Apr 2016 7:57am
shaggydog
Not today but yesterday...
Journey back to my parents to use the workshop for a engine oil change.
All fluids checked and topped up with only the rear diff needing a small top up. Props were greased again and all bulbs checked.
My passenger side headlight had stopped working so I assumed it was the bulb, took it apart (which with the light guards is a bit more involved...) and inexplicably started working again, couldn't find the fault, so put it back together.
Also adjusted the rear drum brakes because they were feeling a bit slack. They have 2 adjusters on them, one ether side and I couldn't figure out which did which so I adjusted them both and have now got a good brake effort again with no rubbing or hot brakes so can only assume its done correctly? Any pointers would be good Thumbs Up
Also fitted a dash cam hard wire kit which has freed up my cigar lighter socket again. Simple kit from Halfords just the usual headache of taking the dash apart and the radio out.
Then gave the underside a good pressure wash to get rid of all the salt, mud and road muck accumulated over the winter and then drove back home for dinner.
Nice to have a day doing routine stuff sometimes Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #522743 10th Apr 2016 12:35pm
