Home > Maintenance & Modifications > Eberspacher Heater for your Defender! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Came across one of these fitted to a Defender the other day. http://www.eberspacher.com/products/air-heating/ Superb bit of kit that doesn't create condensation, used a lot in boats and lorries
9th Jan 2011 10:38am |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Not cheap though, about £1000 arent they?
9th Jan 2011 1:44pm |
Not sure but Ouch! if they are
9th Jan 2011 2:58pm |
Want one myself, heard folk have sometimes managed to salvage them from scrapyards
9th Jan 2011 3:49pm |
Very useful photos Steve
9th Jan 2011 4:45pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Steve
Would be interested to see how you've done the roof plug for the roof tent as that's what mine's going to be for cheers |
9th Jan 2011 4:47pm |
Steve B, which model heater is yours please?
9th Jan 2011 4:51pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
Hi
Thanks, one of my more successful projects Heater id Eberspacher D2 Airtronic ( D= Diesel 2= 2kw ) The connector is the same as you can see on the front of the cubby box http://www.deutschconnectors.eu/ These were salvaged from the bin (s?!t there expensive) but waterproof and small. There must be cheaper alternatives. |
9th Jan 2011 5:05pm |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Being a complete novice as anything to do with electrics (!!!), I have been speaking to a Chandlers in Largs, Ayrshire about this very model.
Was trying to figure out where to put it. I only need it for cabin heating - no tents or anything, so no need for extra ducting. Anyway, planning on getting it done in the next few weeks, so will post photos when complete. |
9th Jan 2011 5:24pm |
cheers steve. which one is it though? mine's being done at ribblesdale and it would be good to get the extra connectors first so they can do the whole thing in one go.
davie, i ve been struggling with that too. thought about the nakatenenga under cubby box thing but its expensive for what it is. i dont want to lose the cubby box storage so the only other realistic option (for me) is on top of a wheel arch just behind the passenger seat. both my under seat boxes are full so cant go in there. |
9th Jan 2011 5:50pm |
Great pics
The one I mentioned was situated under the rear wheel arch I think with hot air blasting into the rear where the guy slept. Legally he had to have it fitted when picking up boats in cold countries below a certain temperature. Had a few pick ups in Norway & Poland! |
9th Jan 2011 6:12pm |
Ribblesdale are really good, everything was perfect when my stuff arrived form them. Post some piccys when they are done.
Right, connectors... I have 2 panel connectors as shown in the picture (mine have 6 connections only and a yellow band), I do not know the part number, 1 on the cubby, 1 on the roof The roof connector has sufficient wire to connect to the cubby with a 6 pin plug part number AS610-98PA The heater control also has the same plug on the end allowing it to either plug into the cubby or the roof, when plugged into the roof the roof wire is plugged into the cubby....still with me Honestly its simpler than it sounds Plugs have caps on when not used. 2 x panel mounts (these are the same as the plugs but panel mount) 2 x plugs AS610-98PA 2 x caps Wires just fitted in the connectors, special tools are required though to crimp. I just searched the UK for a supplier but could not find one best to e-mail http://www.deutschconnectors.eu/ these guys with the part number. |
9th Jan 2011 6:43pm |
BigMike, If you dont mind me asking, what kind of price do Ribblesdale charge for doing all the fitting? I'd like to budget for having one fitted this year.
9th Jan 2011 7:02pm |
steve, thanks for that.
WP, £150. But that's with me supply the ready fabricated aux tank, the eberspacher feed already in it, and the whole thing suitably mounted. If they put it in the main tank the fitting costs is more as they have to drop the tank to get the feed in. I'd have done that myself but I already have an aux wheel tank on the o/s rear and to drop them both simultaneously would be a nightmare, as would removing the aux tank first due to the bleed valve in the base. I didn't want anyone messing with that set up so have designed a new small tank to fit in the n/s rear wheel arch at the front edge. In fact I emailed the sketch to allisport last week. It holds 6 litres. |
9th Jan 2011 7:29pm |
