Home > Maintenance & Modifications > Eberspacher Heater for your Defender!
Page 1 of 4 1234>
Zagato
Came across one of these fitted to a Defender the other day. http://www.eberspacher.com/products/air-heating/ Superb bit of kit that doesn't create condensation, used a lot in boats and lorries Thumbs Up
Post #51934 9th Jan 2011 10:38am
WarPig
Not cheap though, about £1000 arent they?
Post #51966 9th Jan 2011 1:44pm
Zagato
Not sure but Ouch! if they are Neutral
Post #51971 9th Jan 2011 2:58pm
WarPig
Want one myself, heard folk have sometimes managed to salvage them from scrapyards
Post #51978 9th Jan 2011 3:49pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I have one fitted. They are expensive but rather good.
If your going for a used one get it in the summer when they are cheaper, about now they fetch a lot and are usually incomplete. ie quickly removed from work vans with plugs cut off.
I paid £700 for mine from Ribblesdale Auto Electrics through there ebay account a year ago, They supply a UK spec one with the full 2 year warranty.
Fitted into my MSS cubby box
Cubby is quite big, have yet to make a false bottom to reclaim unused space. Doesn't get hot in there.
Guys at work fitted a plug for neat fitting, there is also a plug on the roof outside for heating controls in the roof tent Very Happy
Heat is distributed 3 ways via a manifold at the rear of the cubby box
Exhaust and Air inlet are through the gearbox cover, the exhaust needs a silencer as it is noisy.
The fuel pump sits under the drivers seat, I was lucky enough to have 2 extra spare fuel tanks when I bought the Defender and never used the 2nd spare so this is now dedicated to the heater. As mine is a TD5 it can be fiddly to fit the fuel pick up to the fual tank.
EDIT:
I think WYVERN on here was looking into this also, did you get one ?
Post #51982 9th Jan 2011 4:33pm
WarPig
Very useful photos Steve Thumbs Up
Post #51985 9th Jan 2011 4:45pm
BigMike
Steve
Would be interested to see how you've done the roof plug for the roof tent as that's what mine's going to be for
cheers
Post #51986 9th Jan 2011 4:47pm
WarPig
Steve B, which model heater is yours please?
Post #51987 9th Jan 2011 4:51pm
Steve B
Hi
Thanks, one of my more successful projects Smile
Heater id Eberspacher D2 Airtronic ( D= Diesel 2= 2kw )
The connector is the same as you can see on the front of the cubby box http://www.deutschconnectors.eu/
These were salvaged from the bin (s?!t there expensive) but waterproof and small. There must be cheaper alternatives.
Post #51991 9th Jan 2011 5:05pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Being a complete novice as anything to do with electrics (!!!), I have been speaking to a Chandlers in Largs, Ayrshire about this very model.
Was trying to figure out where to put it. I only need it for cabin heating - no tents or anything, so no need for extra ducting.
Anyway, planning on getting it done in the next few weeks, so will post photos when complete.
Post #52001 9th Jan 2011 5:24pm
BigMike
cheers steve. which one is it though? mine's being done at ribblesdale and it would be good to get the extra connectors first so they can do the whole thing in one go.
davie, i ve been struggling with that too. thought about the nakatenenga under cubby box thing but its expensive for what it is. i dont want to lose the cubby box storage so the only other realistic option (for me) is on top of a wheel arch just behind the passenger seat. both my under seat boxes are full so cant go in there.
Post #52010 9th Jan 2011 5:50pm
Zagato
Great pics Thumbs Up
The one I mentioned was situated under the rear wheel arch I think with hot air blasting into the rear where the guy slept. Legally he had to have it fitted when picking up boats in cold countries below a certain temperature. Had a few pick ups in Norway & Poland!
Post #52016 9th Jan 2011 6:12pm
Steve B
Ribblesdale are really good, everything was perfect when my stuff arrived form them. Post some piccys when they are done.
Right, connectors...
I have 2 panel connectors as shown in the picture (mine have 6 connections only and a yellow band), I do not know the part number, 1 on the cubby, 1 on the roof
The roof connector has sufficient wire to connect to the cubby with a 6 pin plug part number AS610-98PA
The heater control also has the same plug on the end allowing it to either plug into the cubby or the roof, when plugged into the roof the roof wire is plugged into the cubby....still with me Smile
Honestly its simpler than it sounds Smile
Plugs have caps on when not used.
2 x panel mounts (these are the same as the plugs but panel mount)
2 x plugs AS610-98PA
2 x caps
Wires just fitted in the connectors, special tools are required though to crimp. I just searched the UK for a supplier but could not find one Confused best to e-mail http://www.deutschconnectors.eu/ these guys with the part number.
Post #52029 9th Jan 2011 6:43pm
WarPig
BigMike, If you dont mind me asking, what kind of price do Ribblesdale charge for doing all the fitting? I'd like to budget for having one fitted this year.
Post #52040 9th Jan 2011 7:02pm
BigMike
steve, thanks for that.
WP, £150. But that's with me supply the ready fabricated aux tank, the eberspacher feed already in it, and the whole thing suitably mounted. If they put it in the main tank the fitting costs is more as they have to drop the tank to get the feed in. I'd have done that myself but I already have an aux wheel tank on the o/s rear and to drop them both simultaneously would be a nightmare, as would removing the aux tank first due to the bleed valve in the base. I didn't want anyone messing with that set up so have designed a new small tank to fit in the n/s rear wheel arch at the front edge. In fact I emailed the sketch to allisport last week. It holds 6 litres.
Post #52045 9th Jan 2011 7:29pm
Page 1 of 4 1234>
