Home > My Defender > Corris 110....
Page 4 of 48 <123 45 ... 464748>
mcma1
Cheers Ray,
Would be nice to have the exact switch but I think for now I will get it all working and then see what exact I use the switch for...i have it only taking an illuminating feed at the minute so at least it looks like it does something important Smile. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #463357 14th Oct 2015 10:02pm
jk84
This looks better and better every time I look at the thread, top job and great mods. Having said, I have just looked at your other thread for the previous truck and I see where the skills and attention to detail is coming from Thumbs Up MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
MY16 Santorini 90 HT - sold
Post #463617 15th Oct 2015 7:43pm
mcma1
Camera
Ok so fitting an alpine camera as its plug and play into the double din...I was not sure about where to mount it as I didn't want it to catch shot of the rear washer as I need it to tilt enough to show the spare wheel to gauge how far off I am. Had considered moving the washer but then decided the make up a bracket to mount it to the rack. Really pleased. Cable will just run up front and come in with the spots
[/b]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463736 16th Oct 2015 10:08am
ttman333
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Looking very good. Bow down What else is planned?
Post #463739 16th Oct 2015 10:14am
mcma1
Now working on the double din install....
Trimmed the old dash back. You need to be really careful here as it's easy to make a balls of it. I roughly cut it back with a 4" 1.5mm disc and then took some time to sand it back. You need to keep the 2.5mm lip to have the new fascia meet up with the top nicely.
Fitted back in...
GPS antenna hidden away nicely here....
2014 Corris 110 SW
LS3 V8 build...
Post #463752 16th Oct 2015 10:46am
mcma1
Double din fascia collected from the painter, another great job from him.
First thing is to transfer the switches and graphics...you just have to grind off the plastic welds that hold the graphic on and then just super glue them onto the new fascia. Be careful though as if you mark the graphic section it will show up when the lights are on. Also make sure you get a good fit onto the new fascia back to avoid any light escaping around the edges.
I went with the LRI alpine kit, although no instructions come with it at all so you kinda need to just figure out the plan.
You just need to bolt the brackets on to the back of the fascia, you then bolt the HU directly onto these. You don't use the HU cage.
Ready to go!
Remove support bracket.
I then used a pillow to rest the HU on, this lets you mess about with all the wires, connect them up without making a mess of the paint or screen.
Hit a small issue then, with this HU the bottom edge of the clock assembly hits the top of the HU and so the top dash section sits up. Solution is just to cut off the corner edge of the white part.
And job done Smile
Very happy, worth the hassle and blood loss. Just need to tap into the reverse feed now for the camera. Earned a beer or 2. Smile
Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463836 16th Oct 2015 4:48pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Very nice, must be chuffed to bits! Very Happy
Post #463869 16th Oct 2015 7:10pm
mcma1
Thanks, yes I am really pleased. Always admire the trucks that have the double din but never had the nerve to do it. It's turned out really well with the switches moved to the cubby, that was the biggest gamble. Have a few bits nearly ready with FCX which will hopefully bring it along nicely. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463874 16th Oct 2015 7:31pm
ttman333
Love the line "Have a few bits ready with FCX" - cue large delivery of hi-spec kit for more top class fettling! Laughing
Post #463951 17th Oct 2015 6:52am
T1G UP
everyone gets into a 110 in the end Thumbs Up looks lovely, defenders not bad either Whistle
Post #464007 17th Oct 2015 10:03am
mcma1
Time to wire up the spots....
Loom made up and fitted along the rack, I then used the front bracket as the point of entry. Can't been seen at all so very happy. Will connect up after the rugby.. Smile does anyone know the easiest place to tap into the main beam???
2014 Corris 110 SW
LS3 V8 build...
Post #464074 17th Oct 2015 3:16pm
T1G UP
on the way to the relay i'd say.
good luck on the rugger
Post #464082 17th Oct 2015 3:53pm
mcma1
Thanks....We play tomorrow, few Guinness with the boys... Andy
2014 Corris 110 SW
LS3 V8 build...
Post #464084 17th Oct 2015 3:59pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Very nice!!
Congratulations!!
Post #464094 17th Oct 2015 4:26pm
mcma1
So today I finished the wiring for the TS4000's on the rack, nothing too difficult, just tapped into the main beam in the engine bay and also got the cubby switch operating them as well... The light of these is unreal, can't describe how good and pictures will never show it... With another switch lit up now in the cubby and the double din the interior is a nice place to be at night.
2014 Corris 110 SW
LS3 V8 build...
Post #464421 18th Oct 2015 6:14pm
