Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 25 of 81 <123 ... 242526 ... 798081>
mk1collector
I do keep looking at drl bumpers but can't decide if I want round or rectangle lights Laughing I suppose as its a defender it should be more about use and purpose but I like asthetics too and my symmetry ocd is throwing in a curve ball with the other lights on the front being round Rolling with laughter Ray
My build thread
Post #440441 26th Jul 2015 11:02am
barbel jim
IMO looks better without........ be different don't bother
Post #440443 26th Jul 2015 11:05am
mk1collector
I think it's time to come clean Big Cry I'm addicted to changing things Rolling with laughter Ray
My build thread
Post #440447 26th Jul 2015 11:18am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I fitted round DRLs based on that very reason Ray. Keep all your lights round IMO. I will update my thread when the chequer plate returns from the anodisers so you can see what they look like Thumbs Up 2002 110 td5
Post #440514 26th Jul 2015 6:57pm
mk1collector
Thumbs Up I'll look out for it. Ray
My build thread
Post #440785 27th Jul 2015 7:14pm
mk1collector
Got my nas step back from the powder coaters (again) today and although it's not perfect, it's a lot better than last time I picked it up so I'll leave it for now. I put it on and waxed the whole of the inside but forgot to put something underneath on the floor so half an hour later I also had a waxed drive Big Cry
I managed to tidy up the crossmember this week in prep for the step coming back so all I need to do now is refit the wheel carrier Mr. Green oh and put a new rear door on Rolling Eyes
Also managed to find one of these as I shouldn't need to tow anything with this one.
Thanks for looking Thumbs Up Ray
My build thread
Post #441697 30th Jul 2015 4:41pm
mk1collector
All back together now and I think it looks lots tidier Mr. Green also the rattle has gone from the old step which is a bonus. I did have to take more off the wheel carrier to get it to fit though.
 Ray
My build thread
Post #442485 2nd Aug 2015 5:50pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Looking sorted Ray. Where did you get the NAS bung from as I have that setup on my JPN 50th?
Post #442525 2nd Aug 2015 7:40pm
mk1collector
Hi, I ordered from britcar but after a week they decided they couldn't get one but gave me the number for mode Landrover which were showing one left in stock. Ray
My build thread
Post #442556 2nd Aug 2015 9:45pm
mk1collector
My fingers now have lots of cuts again but the first layer of sound deadening is on the roof!
All stripped out
First layer on
Because the roof is big, flat and wobbly I'm putting two layers of deadening on and then the closed cell foam which is Ali faced so it should be quieter, warmer in winter (with no condensation) and cooler in summer. The other layers will go on next week when I have some more free time Thumbs Up Ray
My build thread
Post #443749 6th Aug 2015 2:23pm
Tiger
Makes a big difference I found
Post #443824 6th Aug 2015 7:00pm
mk1collector
Yeah, when I did the bottom half it made a big difference if the top half makes the same improvement it should even be pleasant to drive on the motorway Rolling with laughter Thumbs Up Ray
My build thread
Post #443835 6th Aug 2015 7:38pm
mk1collector
Finally got around to putting the roof back together and with two layers of sound deadening and two layers of closed cell foam it should be a lot quieter Mr. Green
8 square mtrs of this
Gives total coverage twice over the top of the sound deadening.
From this
To this
Also added in another courtesy light for the middle row while everything was out
And all beck together looking standard apart from the extra light
I might look out for a black headlining next Mr. Green
Ray Ray
My build thread
Post #446515 16th Aug 2015 2:57pm
Jimb1978
Good work Ray. Let us know how much difference it has made Thumbs Up 2002 110 td5
Post #446527 16th Aug 2015 3:54pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
That is a really good job! Thumbs Up I am having the dealership install the third courtesy light as they are sorting out a roof problem under warranty also installing some roof insulation but nothing like the job you are doing! That is top notch! Well done!
Post #446530 16th Aug 2015 4:12pm
