Home > Technical > hi lo revs switch
Page 1 of 5 12345>
Caterham
hi lo revs switch
Hi,
I seem to recall when in lo.the revs were increased?
Just moved def back n forth in low and revs are 800 rpm.
could this be dodgy Hi low switch or clutch switch , both, either or neither?
Thanks
Post #430061 10th Jun 2015 7:23pm
LR90XS2011
only works in 1st and reverse DEFENDER 90 TDCI XS,
Post #430074 10th Jun 2015 7:48pm
Caterham
I was only moving back n forth on the drive (1st / reverse) and there was no increase in revs. it remained c799 - 804 revs.....methinks the switch might not be working.....
might also explain why sometimes in hi range I get a seemingly loss of action from the throttle ie perhaps the sensitivity disappears thinking it's in low range?
the fact the revs aren't increasing would suggest there's a problem but can anyone suggest a more robust way of checking this?
thank you.
Post #430107 10th Jun 2015 9:05pm
Nanocom or equivalent.
Post #430121 10th Jun 2015 9:31pm
Caterham
thanks BW.
need to go find someone who can check with one of the above - cheers.
Post #430125 10th Jun 2015 9:43pm
ickle
I thought this was part of the anti stall?
1st gear low ratio up a steep bank with no throttle input from the pedal it should toddle up at 800rpm,
Mine does with a trailer full of logs anyway!
Post #430126 10th Jun 2015 9:54pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I always thought it was the throttle response that was changed between low and high, not the revs.
On my (admittedly TD5) when in low range the throttle response is very much reduced so that bumping along a rough track doesn't cause your foot to affect the throttle so much.
cheers
simon
Post #430129 10th Jun 2015 10:03pm
Anti-stall works in all gears and doesn't alter engine speed, just torque delivery.
Idle jack works in low box 1st and reverse and increases engine speed when the clutch is in and there's no throttle pedal input.
The throttle position mapping is desensitised in low box (less effect for the same pedal input).
Idle jack and TPS mapping require input from (inter alia) the range select switch on the transfer box.
Nanocom etc can read thd ECU input from the range select seitch.
Post #430131 10th Jun 2015 10:14pm
Caterham
regarding throttle response, revs etc as I thought thanks.
just need to get someone with nanocom to confirm it's not getting a switch signal and then find out why?
- something else Crying or Very sad
Post #430145 11th Jun 2015 5:42am
ericvv
Caterham wrote:
I was only moving back n forth on the drive (1st / reverse) and there was no increase in revs. it remained c799 - 804 revs......
Aaaahhh, now we understand why you are getting to more than 500 miles per tank. Laughing You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #430146 11th Jun 2015 6:01am
Caterham
Laughing
just waiting to get everything 100% before my holidays and although I'll be loaded up to the annoyance of the rest of the family I'll be aiming to get some BIG mpg Thumbs Up Mr. Green
Post #430151 11th Jun 2015 6:32am
ericvv
Seriously now, the few times per year that I put my Puma 2.4 into low box (just to keep the mechanism working), the rpm at idle remains at 800, but as soon as I move the gearstick to 1st, the idle revs will immediately increase to 1000, maybe even slightly more and not fall back to 800 again until I put the gearstick back into neutral.
Post #430155 11th Jun 2015 6:54am
munch90
as gearbox has just been out , is the switch connected?
Post #430161 11th Jun 2015 7:57am
RobKeay
Stay out of low box if you want big MPG.
Theres only one way to get to go on holiday that's not in the slip stream of a Eddie Stobart lorry.
Post #430171 11th Jun 2015 8:28am
Caterham
Munch90 I suspect either your right or there was possibly an intermittent problem there that has now failed.
What progress over the last few days ;
Battery earth
New clutch
Ultra gauge (perhaps??)
Hi/ low switch
Running a treat at the moment (and yes I've said this before but I have rectified some actual problems - not some possible problems)
Very Happy v happy
Post #430189 11th Jun 2015 11:06am
Page 1 of 5 12345>
