Home > Technical > hi lo revs switch
Page 2 of 5 <12345>
Cupboard
one thing I hadn't realised until recently about the idle jack (which is the feature you're talking about) is that it doesn't have a switch telling the ECU you're in 1st or reverse. It just guesses you are based on the engine revs and forward speed.
Post #430196 11th Jun 2015 11:29am
^^^ Which is something discussed at some length several months ago!
It uses the range detection switch and speed transponders to determine the gear. Clever stuff.
Post #430325 11th Jun 2015 9:31pm
Cupboard
Exactly, which is the recently I was referring to Laughing
Just thought I'd pass that on Thumbs Up
Post #430442 12th Jun 2015 1:18pm
Caterham
tightened the earth on the battery the other day and all seemed good but now Big Cry
rev counter is waving up /down. not a lot but clearly it's not right. also getting the clatter sound which I'm assuming is the result of a poor electrical signal but why o why o why ?
Big Cry Big Cry Big Cry
Post #431586 17th Jun 2015 9:59am
Caterham
Just tried the hi/lo again after removing the plug on the side of the transfer box (not sure if it was hi/lo or diff lock).... Anyhow tried the hi/lo and in low in 1st no increase in revs while clutch depressed.......and slowly released....and then increased for a bit fluttered about and then went again and can't get them to increase again eight in first or reverse?
Any ideas?
Post #432263 19th Jun 2015 9:08pm
Caterham
I think what I unplugged because was the speed sender - but not sure?
Is the hi/lo switch accessed from above ie cubby box out?
Post #432409 20th Jun 2015 6:04pm
munch90
The speed sender is behind handbrake drum down the bottom
Post #432410 20th Jun 2015 6:07pm
Caterham
Thanks Munch90 - so it was the speedo.
Need to get to the top I presume for the hi/lo?
Cheers mate.
Post #432420 20th Jun 2015 7:10pm
munch90
Might be worth checking one of your posts , check your rods or something , think it may be the one in your own pic
sorry dont know 100% , as never played with switch
Post #432423 20th Jun 2015 7:27pm
Caterham
Hmm good thinking...
I think the link rod changes position of get lever and doesn't impact on the switch ( but not sure)
Post #432427 20th Jun 2015 7:39pm
munch90
Yes , but in the pic , you can see a switch
Post #432428 20th Jun 2015 7:42pm
munch90
Post #432430 20th Jun 2015 7:45pm
Caterham
Thanks Munch90. Will go have a look shortly.
Post #432434 20th Jun 2015 7:55pm
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
ericvv wrote:
Seriously now, the few times per year that I put my Puma 2.4 into low box (just to keep the mechanism working), the rpm at idle remains at 800, but as soon as I move the gearstick to 1st, the idle revs will immediately increase to 1000, maybe even slightly more and not fall back to 800 again until I put the gearstick back into neutral.
Eric
That's interesting.
I drive the 'Spaniel Taxi' in low range on a daily basis.
On mine, the revs do not pick up as soon as either low 1st or reverse is selected.
Having released the clutch, with no throttle input, revs have picked up to just over 1k rpm after travelling approximately 5 or 6 feet.
Not an exact measurement - I just lined the front mud flap up with a dandelion Smile
Am I normal? Laughing '57 Defender 110 XS Station Wagon 2.4tdci
Post #432478 20th Jun 2015 11:15pm
Caterham
hi/lo switch now disconnected, so will see how it goes later?
Post #432529 21st Jun 2015 9:58am
Page 2 of 5 <12345>
