Home > Technical > hi lo revs switch |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
As some kind of guide would have say engaging hi is easier or more difficult than diff lock?
24th Jun 2015 8:25pm |
Sorry dont know what your asking
24th Jun 2015 8:28pm |
oops - I'll try again.
As some kind of guide would you say engaging hi is easier or more difficult than engaging diff lock? Might be irrelevant now anyway. I've been consciously engaging hi/lo and confident it's engaging ok. as mentioned above you can feel (I presume) the spring balls being doing there thing. front prop is back in and things running slightly better but before it went back there was some big 'CLANK' moving from gear into neutral and 'CLANK' neutral back into gear? and pulling away in 1st can be nice and smooth or as tonight about 2k rpm - clatter clatter WTF can it be. having run with front prop out it's not the front axle and having had the rear prop out I'm sure its not the rear axle either. |
24th Jun 2015 10:14pm |
The more you blindly fiddle the deeper in the mire you are going to get. Get someone off the forum who is familiar with 2.4 Puma's to drive it. Steve.
25th Jun 2015 9:12am |
+1
could be just gear clatter , maybe one reason why fords fitted dmf 's on light throttle , hardly any load gears can clatter as your talking about a transfer box of basically 40yrs old design |
25th Jun 2015 9:19am |
+ another 1. Please FFS! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Jun 2015 10:23am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17473 |
Have you tried taking both propshafts off at the same time? You'll find it is quite smooth then.
25th Jun 2015 1:40pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1585 |
if you drive faster you can't hear all these noises. Amazing how long these threads are about one mans 110.
25th Jun 2015 6:58pm |
