Home > Maintenance & Modifications > Rear crossmember grab handle installation!
Page 1 of 3 123>
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
I want to install set of Grab handle onto the crossmember, but then I found there is one bolt is blocking the grab handle lay flat! The white circle one, what is this bolts for? can I remove this bolts?
and seems like no way to put the lock nuts behind the crossmember, any tricks? Question
Thank You Wink
Post #425014 20th May 2015 8:06am
K9F
When I originally fitted my bumperettes I fitted the bolts from the rear. I fed fishing line through the rear crossmember taped the bolt to it and pulled it up through the hole. With a long GS screwdriver it will reach in behind you can hold the bolt head secure enough for the nut to get a purchase whereupon you can tighten it fully.
Alternatively just fit rivnuts. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425025 20th May 2015 9:16am
RF3777
Hi, K9F
How can you taped the bolt to it? Rolling Eyes
Do you mean you use fishing line tight the Lock nut pull out from the hole...
Post #425027 20th May 2015 9:21am
K9F
Tape the thread of the bolt to the fishing line and gently pull the fishing line back out of the hole.....the bolt should follow and eventually the thread of the bolt will come out of the hole. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425029 20th May 2015 9:26am
RF3777
Oh, I see...so you you have the nuts out side of the crossmember! Razz
Did you remove the 2 bolts from the corner? as in my pic circle in white!
Post #425031 20th May 2015 9:28am
K9F
Yes and no but eventually yes! My bumperettes did not need the two bolts in the white circle removing! I did remove them however when fitting my swingaway carrier which subsequently bolted to the two bolts in the white circle. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425042 20th May 2015 9:44am
RF3777
But what is that 2 bolts at corner holding for? Question
My Defender is TD5!
Post #425045 20th May 2015 9:45am
K9F
Not sure but why don't you go and have a look underneath? Whistle
**EDIT** Looking at this I do not think they are structural securing bolts but check anyway......your second photo shows them removed anyway......
http://forum.lro.com/viewtopic.php?f=18&t=6557&start=0 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425046 20th May 2015 9:51am
RF3777
raining a lot out side... Big Cry
Post #425047 20th May 2015 9:54am
K9F
See my edit above. Thumbs Up
Get a brolly or wait until it stops. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425048 20th May 2015 9:54am
RF3777
Sounds like nothing fall off removing that 2 bolts! Mr. Green
Post #425050 20th May 2015 9:56am
K9F
Agree! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425051 20th May 2015 9:58am
Mo Murphy
They normally hold the rearmost seat belt anchor.
50 Shades of Pennine Grey
Post #425066 20th May 2015 10:52am
RF3777
Took a shot even still raining out there!
Thats 2 bolts goes through the crossmember...but something in between may be! Rolling Eyes
Post #425070 20th May 2015 11:01am
RF3777
Mo
So that bolts must not be remove? Shocked
Post #425071 20th May 2015 11:01am
Page 1 of 3 123>
