Home > Maintenance & Modifications > Rear crossmember grab handle installation! |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
You can get them from ebay, or any hardware shop!
they are 8mm diameter! |
15th Dec 2015 12:34am |
The lock nuts is in between the crossmember, its hard to put the lock nuts in there!
What grab handle you got? |
15th Dec 2015 4:00am |
hw7905 Member Since: 05 Oct 2015 Location: Kowloon Posts: 70 |
I want the exact same one as yours bro. And your bolts look nice! |
15th Dec 2015 6:07am |
Correction: should be this one. |
15th Dec 2015 6:32am |
The bolts and nuts I bought from Yeun Long local hardware shop, they are freaking cheap! less then $HK20
15th Dec 2015 6:34am |
Yuen Long? Great. Are they "M8" bolts? Any model no. on them?
Thanks for helping! |
15th Dec 2015 7:43am |
no model number, you can measure from the crossmember to get the exact length you need, remember the bolt can not pass to the back side of the crossmember! so they dont need really long.
15th Dec 2015 7:48am |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Looking at your picture, what is this thing in the utmost right lower corner of the crossmember, with the wire attached ?
May be some sort of parking sensor? Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
15th Dec 2015 8:17am |
Yes, they are parking sensor along with sounds and camera!
15th Dec 2015 8:19am |
Thnx Cheers, Vincent
15th Dec 2015 10:43am |
