Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
@ExCossack - Nice job John, what are the LEDs underneath, Reversing Lights...
![]() And, you seem to be rather well endowed... ![]() With sticky up aerial thingies... ![]() ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Cheers,not a bad job apart from the gas soldering iron being a PITA
Those are a set of rear amber LED strobes lights I use when on the rallies (do recovery) there is also a set below the rear reverse and rear fog lights. I have a pair to go in the front grill as well. The aerials are for rallies as well. From L to R Mount for a 2m/70cms antenna (now moved to the front of the rack), Spare mount VHF High band MSA Low band MSA Low band A system/Red channel depending on the radio Also there is a CB antenna on the drivers side gutter. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Ah, thanks that makes more sense now John...
![]() Rather a lot of holes though... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
The rears are on body mounts and are sealed
![]() Regards John M0VAZ Econet Station 48 no clock |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
Fitted my 110 sticker today, very happy...
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Look good david 👍
I'm toying with some in Mat black on front doors just below mirrors 😄 It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 ![]() ![]() |
Carried on finishing off the double cab back im doing got one of the hatches in so will do the other when I have another quiet spell probably next week or the week after. Starting to look good now though the nice bits are being added even had the defender 2. net sticker put on the rear glass ready for refitting after its been sprayed
Tested the LED rear work lights in the dark - I think I need to alter the angle slightly.
![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Tidied up the rear x-member with a coat of chassis black and fitted the bushes for the clutch pedal mod. I already had the spring but no plastic clip or bushes. I think the pedal feels better.
But without the plastic bushes for the spring to sit in you could see wear on spring. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
I had to get a jump start today, only used the car 2 days ago. The starter sounded fine for the first 2 seconds.. just but wouldn't turn on the 3rd attempt.. just hope it's the battery and nothing else
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Just ordered a Terrafirma + 2" lift kit ( TF204 )
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
That can be a double-edged sword though, when you're up the road in a coffee shop, keys in pocket, find a comfy chair to settle down into and you unlock vehicle without realising it. Wasn't there a supposed urban myth/truth that the range could be extended by placing the fob near your open mouth when plipping it.... |
/\ Its not an urban Myth holding it to your head, it does work further away. Dont need your mouth open though.
Go and try it ![]() |
Replaced the snapped bonnet stay clip for the 3rd time! 1999 Defender TD5 110
