Page 769 of 1383 <123 ... 768769770 ... 138113821383>
excossack
Finally got around to fitting the LED lights I purchased. Queue the pictures.
Old lights 55w
Bracket hardware, with adjustable angle and on the back of the lights is a semi captive nut that can slide the main body of the light left/right
Old and New
And finally
All I need now is some darkness to test the spread of light 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #392391 25th Jan 2015 2:29pm
Venomator
@ExCossack - Nice job John, what are the LEDs underneath, Reversing Lights... Question
And, you seem to be rather well endowed... Shocked
With sticky up aerial thingies... Whistle ... Rolling with laughter
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #392393 25th Jan 2015 2:36pm
excossack
Cheers,not a bad job apart from the gas soldering iron being a PITA
Those are a set of rear amber LED strobes lights I use when on the rallies (do recovery) there is also a set below the rear reverse and rear fog lights. I have a pair to go in the front grill as well.
The aerials are for rallies as well. From L to R
Mount for a 2m/70cms antenna (now moved to the front of the rack),
Spare mount
VHF High band
MSA Low band
MSA Low band A system/Red channel depending on the radio
Also there is a CB antenna on the drivers side gutter. 1999 Defender TD5 110
Regards
John M0VAZ
Post #392398 25th Jan 2015 2:42pm
Venomator
Ah, thanks that makes more sense now John... Thumbs Up
Rather a lot of holes though... Whistle
 Rog... Mr. Green
The GREEN One...
Post #392409 25th Jan 2015 2:57pm
excossack
The rears are on body mounts and are sealed Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #392410 25th Jan 2015 3:05pm
Cheshire110
Fitted my 110 sticker today, very happy...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #392425 25th Jan 2015 4:03pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Look good david 👍
I'm toying with some in Mat black on front doors just below mirrors 😄 It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #392500 25th Jan 2015 6:29pm
SailingTom
Carried on finishing off the double cab back im doing got one of the hatches in so will do the other when I have another quiet spell probably next week or the week after. Starting to look good now though the nice bits are being added even had the defender 2. net sticker put on the rear glass ready for refitting after its been sprayed Smile
 Defender puma dormobile camper
Post #392528 25th Jan 2015 7:28pm
excossack
Tested the LED rear work lights in the dark - I think I need to alter the angle slightly.
Regards
John M0VAZ
Post #392546 25th Jan 2015 7:59pm
excossack
Tidied up the rear x-member with a coat of chassis black and fitted the bushes for the clutch pedal mod. I already had the spring but no plastic clip or bushes. I think the pedal feels better.
But without the plastic bushes for the spring to sit in you could see wear on spring. 1999 Defender TD5 110
Regards
John M0VAZ
Post #392764 26th Jan 2015 6:44pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I had to get a jump start today, only used the car 2 days ago. The starter sounded fine for the first 2 seconds.. just but wouldn't turn on the 3rd attempt.. just hope it's the battery and nothing else Evil or Very Mad
Post #393290 28th Jan 2015 12:17pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Just ordered a Terrafirma + 2" lift kit ( TF204 ) Very Happy Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #393327 28th Jan 2015 2:12pm
PCA42 wrote:
Did the 'alarm remote aerial' mod today, extended up into the roof lining. Very much recommended, can lock it from miles away now instead of 2 ft! Thumbs Up
That can be a double-edged sword though, when you're up the road in a coffee shop, keys in pocket, find a comfy chair to settle down into and you unlock vehicle without realising it.
Wasn't there a supposed urban myth/truth that the range could be extended by placing the fob near your open mouth when plipping it....
Post #393330 28th Jan 2015 2:24pm
SailingTom
/\ Its not an urban Myth holding it to your head, it does work further away. Dont need your mouth open though.
Go and try it Very Happy Defender puma dormobile camper
Post #393336 28th Jan 2015 3:08pm
excossack
Replaced the snapped bonnet stay clip for the 3rd time! 1999 Defender TD5 110
Regards
John M0VAZ
Post #394156 30th Jan 2015 7:33pm
