![]() | Home > Technical > Nolden / Speaker EVO2 headlamp comparison discussion |
Guess they won't pay my invoice for royalty charges, no?
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
^^ Daniele, you are wearing some very tinted glasses yourself now with comments like that.
![]() In my native language there is a perfect saying for what you are doing: Spijkers op laag water zoeken. Feel free to translate this in the right spirit, but it will be a challenge I think. ![]() Now to properly clarify this issue.... In my particular case, both the Nolden and the Speakers would have run into the same electric problem at that time. The problem was a combination of me having: 1. the SVX front with aux high beam lamps, and 2. fog lights properly installed in the legal way. This point 2. you do not have on your truck I believe, So. when my 7 inch Wipac main headlamps were replaced by the Speakers, there was actually not a problem with the Speakers, but somehow my 90mm aux high beam lamps kicked in with the Speaker low beam and/or my fogs, which they should not do, but which my dealer in the end defined as being caused by the LED headlamp electronics. The same thing probably would have happened with different LED headlamps and their electronics too with my particular lights set up, so including the fogs. It was all a bit of trial and error to solve it, but my dealer found that diodes did not help, but the solution came in the form of an extra relay to the negative feed of the Speakers, in order to entirely disconnect them from the aux high beam signal and from the fogs. The Speakers now have in total 3 dedicated relays. So bottom line, nothing to do with the Speakers per s�, but more with the specifics of the SVX light setup and the fogs. With the extra relay, it all works picture perfect now. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Eric
you do not have to explain and/or justify anything it was just an "ouch" because it seemed like a "cheap shot" (italian expression) I have the highest regard for you as for many others here in the forum ![]() Now we all sit around a big round table and.......... ![]() Click image to enlarge .......haaaa typical Italian diplomacy....... ![]() ![]() ![]() ![]() ![]() IID Pro MV License |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3791 ![]() ![]() ![]() |
So these are Noldens? Pickles. |
Yes they are Noldens
![]() Brendan |
Well then, I can't see L.R. fitting something which they might have a problem with.
Pickles. |
Pickles....
![]() After 70 odd years? Never mind the friggin' lights they've got enough on their plates with the rest of the leaky, rattly, rust bucket as it is! Don't we just love 'em? They should vhave gone with the 8700 J W Speakers in line with the rest.....wet inside! ![]() Eric it was a joke......no need to get your knickers in a twist! ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Just my pennys worth for looks that i think suit the defender , the noldens win hands down !
Update (and wavering slightly off course), my first Evos had a condensation issue due to the stainless bezels contacting the aluminium headlamp body at the bottom where water collects
![]() Back to the thread: I think it should be pointed out that the Speakers have a lifetime warranty - not sure if the Noldens do? As far as LR fitting "the best lights" to the last Defenders - what a joke. The vehicle is being killed off and still doesn't work properly. Think about the other disastrous expensive/crappy/rusty accessories LR "recommends". I would rather steer away from anything LR sees as suitable to put on the vehicle than rush to buy it ![]() p.s. Happy New Year from a miserable sod ![]() But shout it at them in German because life is also terrifying and confusing... |
Speaker 8700 Evo's to my knowledge have a Limited lifetime warranty Noldens Bi Led have a 3 year warranty. Personally I would not worry about the Noldens only having a 3 year warranty. Have you heard of one report of Nolden lights suffering from condensation or water ingress? Or suffering from corrosion? Flickering? Time delay in going from main beam to dipped beam? In 2014 we sold several hundreds of light units from the Nolden range. We have not had one light unit returned or one complaint about condensation/corrosion etc. The worst 'issue' we had was a customer fitting Nolden BiLed to a 1986(?) G Wagen in London. The problem was with the headlight bulb failure system of the vehicle. Solution? We got an English speaking technician from Germany to actually phone the customer up, talking him through fitting a suitable supplied resistor and then clearing the fault codes on the vehicle. Once fault codes were cleared everything was fine ![]() Brendan |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
Thanks Eric! You rely somewhat helps in clearing out the light performance in the rain and possibly other weather as well. Still watching the topic to see which light is the better buy as they are not cheap, I cannot afford to just keep changing and would prefer to buy once and hurt once. Thanks again! |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 ![]() ![]() |
For what it's worth, I recently upgraded from factory fitted SVX Wipacs to the latest Noldens. I'm very impressed with the improvement in lighting and the quality and finish seems very good.
Part if my choice is that the Noldens are quite subtle looking and blend in very well (imho). The ip69k rating is the highest you can get and gives me absolute confidence that these units should remain entirely waterproof no matter what the conditions (including direct hi-pressure washing with the Karcher). Great product and great service from Brendan too ![]() Either way, LED lights do take some getting used to but are a great improvement. |
I have to admit the way the Speakers look a little different/aggressive is one reason I am happy with them, even if the IP specs of the Noldens are impressive i.e. vanity plays no small part
![]() In any event, the performance of LEDs in general is outstanding compared to other vehicles and should be fitted to ALL Defender models as standard ![]() But shout it at them in German because life is also terrifying and confusing... |
