Home > Technical > Nolden / Speaker EVO2 headlamp comparison discussion
Page 6 of 7 <1234567>
I also think Nolden might come out on top tomorrow Rolling with laughter
Post #385612 6th Jan 2015 9:21pm
dgardel
Italy
K9F wrote:
Daniele I believe has also 'moved away' from J W Speakers.....
dgardel wrote:
.....the new evo made oxidations after 2 months. I had to put the silic�n grease.
By the way, nolden case quality seems better.....
If you look closer the JWS, in my opinion, the company have quality problems and not all pieces was made with the same precision (eg different beam pattern)
dgardel wrote:
The evo ones suffers from the SS contact but a good anticorrosion grease solve the problems.
I don't have any vested interest apart from the fact I own a set of J W Speakers and wish I didn't. Interestingly my second quote in one of my previous posts was written by yourself was it not confirming there were a limited number with issues?
Regularly inspect your lights including taking them out periodically would be my advice and then you may be able to deliver concrete solid evidence of their improved quality yourself.
Thumbs Up
I confirm everything Thumbs Up Thumbs Up Thumbs Up
Also my EVO had corrosion in the areas of contact between the case and the ring and the condensation issue.
Another problem was the flickering effect just after the engine start up. true that disappear after a few seconds, but over the time could be cause of problems to the LED string.
Personally I think that the Nolden outweigh the JWS EVO2.
The evo 2 have a pattern that, with the hi-beam selected, illuminate more nearby the "nose" of the defender but Nolden "shoot" at a greater distance (imho, better HI-BEAM).
but this image amplifies this effect and, in my opinion, does not reflect reality
When "Low beamed" Nolden and EVO2 not show significant differences, may be JWS has a spot well illuminated very closer to the car but with a not well illuminated area just next .
Last but not least I noticed that these effects (such as photo effect) are very sensitive to the adjustment of the headlights, are sufficient 2 or 3 degrees more or less of difference of inclination. May be related tho the sharper pattern of the LED headlamps Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #385628 6th Jan 2015 9:50pm
ericvv
Daniele, when you say that "Personally I think that the Nolden outweigh the JWS EVO2."...
I presume that this means that you have already tried them, yes?
If correct, as you have the SVX front,I presume you have tested the EVO2 with front position light. Since the EVO2 with front position light also has integrated DRL, I would be interested to see pictures of this EVO2 with 1. only the DRL on, and 2. with the position lights on. In the last case I presume that the DRL turn off, and from pictures seen it seems that the DRL and the position light are one and the same (top half circle) LED unit. I guess that it probably means that with the lights off and DRL on, the entire half circle is lit up as DRL, and that with position lights on, only part of the same half circle stays on as position light. ????
By the way, I never saw a picture posted anywhere of how the Nolden position lights look when on. Think I never even saw a picture of the Nolden with position lights in the first place. I know a few Defenders here in Geneva with Nolden, but they all have the standard front, so with separate position light. Anybody has such pictures and can post?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #385788 7th Jan 2015 6:41am
Noticed the lights on the special editions Thumbs Up
Post #385791 7th Jan 2015 6:58am
Pickles
ericvv wrote:
Pickles, that is probably not a Hella, but a vintage Marchal light. You can find those on the internet.
Rgds, Eric
Don't think so Eric, Definitely a Hella,.....unless you have actually seen a Marchal with the writing on the lens as described?
Pickles.
Post #385793 7th Jan 2015 7:10am
There are some video demos of various LED headlights on here
http://www.headlightrevolution.com/LED_Headlights_s/1822.htm
And some familiar photos... Of Eric's truck on this website
Here is a comparison of jws evo vs jws evo 2
http://www.headlightrevolution.com/JWSPEAK...tion2b.htm
Post #385802 7th Jan 2015 8:30am
walfy
Don't follow the logic here!
You're implying that because they are fitted to the last Defenders they are the best???
Is that because they are fitted to a vehicle that doesn't rust?
Is it fitted to a vehicle that is going out of production?
Is fitted to a modern vehicle with a pants alarm system
Is fitted to a vehicle with a dubious build quality?
Or did LR just get a great group buy and found them at a mega cheap price.
Just asking like Whistle Whistle Whistle 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #385857 7th Jan 2015 11:05am
Thats why I Rolling with laughter
Speakers Rock Thumbs Up
Post #385862 7th Jan 2015 11:22am
walfy
I'll take your word for it. Can't see any LED lights appearing on my 110 in the near future Thumbs Up 110 D250 SE HT
110 USW SOLD
Post #385866 7th Jan 2015 11:25am
dgardel
Italy
It's really curious how we take the parts with one or the other type of lights almost fighting ......
haa human nature ....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #385868 7th Jan 2015 11:27am
ericvv
Post #385894 7th Jan 2015 12:40pm
Eric .. here http://www.headlightrevolution.com/Nolden_...l-7led.htm
click on the small images in the gallery, bottom row, 2nd from right (you and Loius)
Post #385903 7th Jan 2015 1:14pm
dgardel
Italy
IID Pro MV License
Post #385904 7th Jan 2015 1:17pm
Nice to see they asked Rolling with laughter
Post #385905 7th Jan 2015 1:23pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I know. It's amazing. Eric's rose-tinted glasses also seem to be preventing him from remembering actually getting his EVOs working properly in the first place.
I remember this because I replied to his appeals for high-powered diodes at the time.
http://www.defender2.net/forum/topic15899.html
Pete
Post #385916 7th Jan 2015 2:06pm
