Home > Puma (Tdci) > Diff oil change plug torque
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi everyone,
Any idea of the tightness of the drain and filler plug on the diff (nothing in the manual)?
I am sure it is a tapered fit but not sure how tight it should be.
Any contributions gratefully received.
El Pepe Flamenco JLS
'El Pepe Flamenco'
Post #37482 2nd Aug 2010 10:10am
Setok
Finland
Aren't drain and fill plugs generally the kind of thing you just tighten "enough". I know that's the way it used to be anyway in the good old days Smile
Post #37491 2nd Aug 2010 12:28pm
Tim_NZ
Australia
I can't find any spec anywhere, even for a series LR. Just don't wind the plug all the way into the diff, that's a real PITA!
Cheers,
Post #37497 2nd Aug 2010 1:35pm
jst
i dont know the official figues but they are not that tight 30-40Nm? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #37498 2nd Aug 2010 1:36pm
jlerra
Thanks, all, for your help.
Will approach the tightening up with caution!
'El Pepe Flamenco'
Post #37500 2nd Aug 2010 1:43pm
bob neville
Front drain and filler plugs are 60nm (44lb ft) according to the workshop manual, rear is not specified.
Bob
Post #37510 2nd Aug 2010 2:27pm
spudfan
Ireland
In the Defender manual pre Puma it gives 55-64 Nm or 40-47 lbf ft. It would appear that bob neville is bang on. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #37520 2nd Aug 2010 5:19pm
Bit of a thread revival but thank-you to Bob two posts above for that info. Just what I was looking for! πŸ‘πŸ» WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #720109 28th Jul 2018 7:04pm
