![]() | Home > Puma (Tdci) > Diff oil change plug torque |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi everyone,
Any idea of the tightness of the drain and filler plug on the diff (nothing in the manual)? I am sure it is a tapered fit but not sure how tight it should be. Any contributions gratefully received. El Pepe Flamenco JLS 'El Pepe Flamenco' |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
I can't find any spec anywhere, even for a series LR. Just don't wind the plug all the way into the diff, that's a real PITA!
Cheers, |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8207 ![]() ![]() ![]() |
i dont know the official figues but they are not that tight 30-40Nm? Cheers
Thanks, all, for your help.
Will approach the tightening up with caution! El Pepe Flamenco JLS 'El Pepe Flamenco' |
Front drain and filler plugs are 60nm (44lb ft) according to the workshop manual, rear is not specified.
Bob |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
In the Defender manual pre Puma it gives 55-64 Nm or 40-47 lbf ft. It would appear that bob neville is bang on. 1982 88" 2.25 diesel
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Bit of a thread revival but thank-you to Bob two posts above for that info. Just what I was looking for! ππ» WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
