![]() | Home > Maintenance & Modifications > Increasing reverse light illumination |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
Double Scenelite. Quite expensive but plenty light...
http://www.mudstuff.co.uk/products/electri...e-s17.html ![]() Click image to enlarge |
Windowlicker Member Since: 24 Aug 2014 Location: East yorks Posts: 290 ![]() ![]() ![]() |
I too have the Scenelite fitted, mine is mounted centrally, ( need to relocate the water jet nozzle) just above the dogs head
![]() Nicely made , warranty back up and seems robust , impressively bright and very low power draw, so can happily be left on for extended periods. I have mine switched above the rear door, in between the two grabs handles, and also a switch on the dash for using whilst reversing if needed. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge When fitted , it really is aesthetically very subtle, doesn't stand out like a sore thumb, and looks pretty integrated/factory ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
There are a couple of different types of lights (LED or filament) which could be used and a vast range of different lights varying from about a tenner up to a few hundred pounds.
So a few points to consider. IP rating say IP67 so it is reasonably storm proof. If just use as a reversing light with engine running yes filament will be fine, if used for long periods of time especially with engine off then LED is the way to go. One or two extra lights, adjustable angle or fixed?. Two adjustable lights will give a broader spread of light then one or two fixed. Light output? If just used as reversing lights you could have two lighthouse bulbs as long as use does not dazzle other drivers. If used as work lights/camp lights you do not want them too bright as if you look at them directly you will be 'blinded' so no mega large mega bright LED light bars. Brendan |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 761 ![]() ![]() ![]() |
Can you show us how these look lit up and how things look when the lights are on? Thinking of going this route as well then probably wire them up to a 3 way switch so they can either turn on with reverse, or just normal reverse, or just on when not in reverse. Thanks. |
My pics above of the Grey 90 are of the same light, mine is black Hans has the White ones.
The LEDs are actually set in a slight radius, so they have a large footprint, hence sold/suggested as a scene light rather than a more specific focused or narrower footprint. ![]() |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 ![]() ![]() ![]() |
Switched Mud light for me
![]() ![]() Click image to enlarge "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
I do not have any night time pictures but here is one in the rain.
My Scenelites are not wired to the reversing light but are operated by two independant switches. ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks HansT, TooTall, & Windowlicker!
So I take it that HansT's set up will give a wider arc of illumination? Will it be necessarily be brighter? Now that I think about it, I think wiring them up to a factory switch on the panel and using them when needed is more appropriate and less complicated. Looks like it's almost time to ring up my local Mud distributor... |
A friend of mine here has this mud light installed on the right hand top corner of the roof. Very, very good light output, even by a single unit.
As I have the famous live purple wire in the loom behind the right hand side interior rear panel (which all Pumas up to/including model year 2011 have) I am thinking of buying such a black Mud light too, with an easy connection to a on/off button in the rear interior panel next to my aux 12V power socket. An additional advantage of this mud lamp (at least for me ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
These are on my wish list, ill be getting the full tail compliment giving dual fog and dual reverse. Combined with the work lights( in the garage in their boxes waiting fitment...still) I'm sure ill have no trouble seeing behind me, also llooking at fitting a camera so I can load the trailer alone
Vince VDB Member Since: 17 Nov 2014 Location: Champagne sur Oise Posts: 60 ![]() ![]() ![]() |
Hi Where this purple wire arrives ? Defender 110 Puma 2.4 SW SE Defender 90 300 Tdi SW with TD5 body Land 90 V8 HT |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5882 ![]() ![]() |
Look here
http://www.defender2.net/forum/topic20319.html Andy |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
I've got a camera fitted with infrared led fitted so no need for the extra light...
Thanks a lot ![]() Defender 90 300 Tdi SW with TD5 body Land 90 V8 HT |
