Home > Maintenance & Modifications > Increasing reverse light illumination
Page 1 of 7 1234567>
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Any one got any ideas how I can increase the illumination of my reversing light without resorting to a work light. I live in the sticks and the standard reverse light intensity on my new 90 is inadequate..
Thanks
Dave
Post #373038 20th Nov 2014 4:03pm
LED, much brighter and lower power consumption.
Post #373039 20th Nov 2014 4:05pm
By that I mean an E marked LED unit from the factory that is legal.
Such as the Wipac version.
Fitting LED fixtures into the original holder is illegal.
Take a look here:
http://www.ebay.co.uk/itm/Land-Rover-Defen...43d06f3ade
Post #373040 20th Nov 2014 4:07pm
Dave-H
TBH Steve, I have the wipac LED one on my 90 and It's not that great an improvement. Better yes, but still not fantastic.
Better option is doubling up and fitting 2, one each side Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #373045 20th Nov 2014 4:32pm
munch90
yes I found the same not enough of a improvement, so went the double route too , 2 fog + 2 rev
Post #373046 20th Nov 2014 4:38pm
shaggydog
I put a work light on.
Normal reverse light for most things but then if I need I can switch it on and see everything. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #373050 20th Nov 2014 4:50pm
A work light is ideal if you've got a trailer too, in particular if it's LED as you don't have to worry about the battery drain quite as much.
Post #373058 20th Nov 2014 5:09pm
munch90
also work light comes on , on mine too and I got it switched so can have w/l on with reverse , off , w/l alone
Post #373060 20th Nov 2014 5:18pm
LR90XS2011
I have tried an aftermarket LED (filament bulb replacement) of the type that are common on e/bay and it made a massive difference and was only about £5 however as others have said not strictly legal. A good alternative is a work lamp that can be switched from the cab, however again not strictly legal if used when reversing DEFENDER 90 TDCI XS,
Post #373063 20th Nov 2014 5:20pm
Litch
As above. Just upgrade to a pair of the round reversing lights but when you do it make sure you go for fully road legal E-marked units such as these Le Perie units.
Seriously bright. Cool
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ONE LIFE, GET IT!
Post #373067 20th Nov 2014 5:28pm
ericvv
I have the Le Perei led reverse light as standard on my SVX, and it is worthless. As good as the SVX Le Perei tail/stop light units are, as well as the led fog, as poor I find that reverse light.
The Le Perei fog throws better (red) light far behind the truck than the white led light of the reverse. Strange I think, and don't have a real explanation. Just to be clear, the reverse light is in fine as new condition, no disfunctioning LEDs or so.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #373089 20th Nov 2014 6:33pm
Vince VDB
France 2008 Defender 110 Puma 2.4 XS CSW Santorini Black
Two Bolt on Bits reverse Led Lights on the right side of the 110, its ok, not fantastic but correct.
 Defender 110 Puma 2.4 SW SE
Defender 90 300 Tdi SW with TD5 body
Land 90 V8 HT
Post #373105 20th Nov 2014 7:17pm
JWL
Just doubling up the reversing lights is one hell of an improvement. It's not a difficult job, be prepared to wield the drill and you'll be fine. It can be as cheap, I used second hand bits I picked up from an autojumble, or you can go the whole hog and buy new fancy led sets from one of the forum.
Post #373135 20th Nov 2014 8:38pm
Merlin
Wire your worklight to the reversing light. There is a thread on here showing how.
Merlin
Post #373154 20th Nov 2014 9:19pm
leeds
Under Vehicle Lighting Regs only 2 reversing lights are required and they do need to be type approved/E marked.
Good alternative is two work lights high up angled out slighty so you get a better spread of light.
Wired and switched separately legal as work lights, not legal to use as reverse lights on the public highway, however legal to use as reverse lights off road.
Brendan
Post #373156 20th Nov 2014 9:26pm
