Home > My Defender > Overland 110 Build from the Ground Up!
Page 6 of 11 <123 ... 567 ... 91011>
Barrowboy
United Kingdom 2006 Defender 90 Td5 HT Blenheim Silver
Fantastic thread from start to finish. Thank you for sharing and, by the way, it's very unusual to have a rebuild thread with so many pics featuring cloudless blue skies!
I'm not ready to rebuild yet (either monetarily, skill-wise or need right now) but this one's saved in my favourites for when the time is right!
A man always needs a 'project' but this winter's taken care of with a RIB refurb!
Post #371980 16th Nov 2014 2:10pm
familymad
All time best spec and fav re build thread.
Excellent work. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #372000 16th Nov 2014 4:07pm
familymad
Did you want to sell it and try another build ...... Whistle 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #372001 16th Nov 2014 4:08pm
IanT599
Absolutely amazing build. Great info on the Koni shocks and that you had to up to 25mm hd anti roll bars.
Any further ideas on where you are mounting the air tank?
Post #387832 12th Jan 2015 8:52pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Hi Rob,
Where did you purchase your paint stripper from?
Thanks
Andy Working towards Carry on camping!
Post #387847 12th Jan 2015 9:24pm
90Ben
Great build thread!!
Post #387868 12th Jan 2015 10:01pm
Defender_Td5
1991 Defender 110 300 Tdi USW Stornoway Grey
Andy80 wrote:
Hi Rob,
Thanks
Andy
Hi Andy,
The paint stripper was purchased from these guys:
Strippers Paint Removers Tel: +44 (0) 1787 371524
The product I used was called NB-510, although the name seems to have changed now, it's probably best to give them a ring.
http://www.stripperspaintremovers.com/view_products.htm Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86"
Post #387895 12th Jan 2015 10:33pm
Defender_Td5
Hi Ian,
Thank you for the kind words! Like all these projects they are never really finished I guess. The Koni shocks are brilliant without a doubt, I just think my vehicle was a bit heavier than the standard set up on top due to the external roll cage and the roof rack. I will say that the HD Anti Roll bars certainly transformed the handling and were well worth the expense.
To be honest I haven't been in the country for around 6 weeks so I haven't been able to carry out any work on the truck as of late. However the following is planned when I get back:
- Finally wire up the Light Force 170 roof rack spot lamps
- Wire up the two rear LED flood lamps
- Fit two new Tdci XS Heated front seats and wire these up
- Fit new XS seat covers purchased for the Tdci Second Row Seats to match the front.
- Remove all wheels and tyres - wheels to be repainted in satin black and the BFG KM2's taken off and replaced by 265 75 16 General Grabber AT2's. I will keep the BFG KM2s for muddy adventures.
- Remove and service the front double de-cardan propeller shaft.
Then I might get some time to sort out the air tank and compressor placement! The trouble I have is I wanted to fit another sill tank on the left hand side for water at around 65L, this however would be the perfect place for the receiver tank though. At the moment I am still very much undecided on what to do with this. I also have all the air pipework, fittings and quick disconnect airline outlets that I want to fit to pipe air around the truck to make it easy to air up tyres - again this is a work in progress type thing.
I'll update the thread with a work in progress update when I am back in Aus and cracking on with the truck.
Rob Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86"
Post #387906 12th Jan 2015 11:05pm
Cheshire110
Just reading through this all again. I'm absolutely blown away.
Absolutely the best defender I've ever seen in my entire life, no shadow of a doubt! Simply incredible.
Nothing over the top or superfluous and no corners cut. I would have thought it would be worth at least double what a new one would be!
Simply incredible, well done. Bow down my dream one day! Cheers, David
Post #387917 12th Jan 2015 11:22pm
Defender_Td5
Wow David! Some serious praise there....thank you very much! I am now taking orders if you wish to have one built Wink
I often get asked why didn't you just buy a new one, some people I guess just don't understand Defenders and likely never will. With Land Rover finishing up production some time this year I expect our Defenders will hold their value even better.
Series 1 86"
Post #387936 13th Jan 2015 3:42am
IanT599
I'm worried that they are going to hold their value more now at the end of the year.
I need one as a donor vehicle for my build. They're expensive enough already for salvage ones Laughing
I think the simple reason is that people have in your head the ideal vehicle. Some achieve it through simply fitting a black pack or NAS lights etc. Some achieve it from a ground up rebuild like yourself.
You know then that you've got the best vehicle you want.
I want a V8 auto Defender. They don't make them anymore so I have to build it. I want a 90 for its size but I want a 110 for its space. They don't make it so for me it'll be a 100" with the 2 flip down seats.
Well that's a couple of reasons why I want to do a self build but the list is very long of why I want to do one.
Your build is great inspiration to people that want to build one. Ian
2004 Discovery II TD5 ES Auto
1990 Range Rover Vogue Efi Auto (Future 100" Defender Puma)
2015 Compass Rallye 644
Sankey Mk3 Wide Track
Post #387957 13th Jan 2015 8:13am
Grenadier
Just read the thread from start to finish. Huge thanks for all the photos and info, they shall be saved for later referral, as my ambition is to fully 'overland-prep' my 110. A simply exceptional re-build, as many have said, the best I've seen. Brilliant. Makes me feel not a little humble as I was considering uploading my 'project' which was merely adding some 'bling' to a 2011 110SW. Think I'll pass now!! If you ever drive back to the UK, do pop into Chamonix and say hello, be great to see the vehicle in the flesh....Great job. Bow down Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #387978 13th Jan 2015 10:14am
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
What a fabulous thread. Read from start to finish and enjoyed far more than any of the apparently LR-related comics one can buy in WHSmith. Thank you very much. Now, where do I send my Ł4.00...?
You may have mentioned it, though I did not see it. What headlamp protectors have you used? I fancy some additional protection and security for my Noldens but do not want to drill any uncovered bodywork.
Thanks,
Joel
Post #389148 16th Jan 2015 7:04pm
Grenadier
Joel, I think they look the same as mine and are the new, lower-profile Masai lamp guards (if you're referring to the front). Very smart, easy to fit.
Voila:
http://www.masai4x4.com/#!/New-Style-Masai...ory=821961 Monsieur Le Grenadier
Post #389310 17th Jan 2015 9:18am
T1G UP
check out davew and pamw as he has a 100" ls3 engined auto 100" 90! awesome
Post #389332 17th Jan 2015 10:54am
