![]() | Home > Technical > Nolden / Speaker EVO2 headlamp comparison discussion |
Brendan, we know that you do have a slight
![]() When it comes to lumen numbers, Nolden and Speaker do not use the same language, so comparing numbers of one with numbers of the other makes no sense whatsoever. It really is a case of comparing apples with pears. Nolden give the following numbers: Lumen/Lumens (LowBeam/HighBeam) 1880lm / 2400lm (calculated) ~1550lm/~1700lm (measured) Speaker for the EVO2 give these numbers then: Raw Lumen Output: 2,610 (High Beam); 1,770 (Low Beam) Effective Lumen Output: 1,150 (High Beam); 750 (Low Beam) So Nolden speaks about "calculated" and "measured", Speaker about "raw" and "effective". (Speaker used that very same terminology for the first EVOs too) By my knowledge, the question to put these light output numbers for both of them under one common denominator, so the same type of lumen, be it calculated/measured, or be it raw/effective, has been asked here on the forum several times, but nobody ever was able to answer that question apparently. Nobody ever gave a real explanation how you can translate one terminology into the other to get to level playing field.... Until that happens, we should not give too much credibility to any lumen numbers people use on here to show that one is better than the other. Sofar the only thing which is a fact is that we did a real down to earth side by side eyeball test of the previous generation Speaker EVO and the Nolden (link below). The result is that as far as light output I think we can say with confidence that any difference was hard to notice between those two. http://www.defender2.net/forum/topic21619....ker+nolden Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 3rd Jan 2015 3:53pm. Edited 3 times in total |
Fair comments about the deal offer. But the point about comparing xxx lumen with yyy lumen remains valid nevertheless, and it is definitely misleading.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Eric I know where you are coming from. This topic is starting to remind me of who is the best tuner to use, and we know how much animosity that caused. It is all down to personal preference. As to quoted lumens etc, as a seller Brendan can only quote the official values released by the suppliers and offer advice on his own personal choice as he like myself is in the position of having both sets of LED headlights, so can offer up his own conclusions as to which set he prefers fitted to his landrovers.
Brian, not much different from me, except for the fact that I am not a seller of course. But we do have the luck here to have two Pumas parked side by side in our spacious underground parking garage with nice white walls which allows a real side by side comparison in the best of circumstances.
I also understand that Brendan as you say can only give the official values released by the manufacturer, and the same goes for those who sell the Speakers. But my point that in those circumstances it feels a bit colored to throw out these apples and pears numbers as has been done frequently on here to proof that one is better than the other, remains a bit useless as I said. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Looking at Lorryman's pictures I am confused by 1 thing:- on high beam the area immediately in front of the vehicle seems less well illuminated than on dipped beam; I thought the Nolden's main beam was in addition to the dip beam? Or does it do a swap from dip to main?
Mark. |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Sorry Eric, but it is not an apples and pears comparison and is an effective and recognised manner of indicating the numbers, whichever terminology is used! ... ![]() Calculated is raw is calculated and they mean the same thing, likewise, measured is effective is measured, in either language... ![]() To simplify the reasoning and add substance... Raw Lumens The "Raw Lumen output" is calculated by multiplying by the theoretical rated output of the LEDs by the number of LEDs in the lamp. Hence, it is also a calculated value. Example: 8 LEDs rated at 100 Lumens per watt 8 x 100 = 800 Lumen Effective Lumens The "Effective Lumen output" is a measured number that takes into account real world losses (ex. thermal, optical, and assembly). Therefore, this output gives a measured value. Example: Raw Lumens = 800 Less - Thermal, Optical & Assembly Losses = 40% Effective Lumens = 480 Lumens I hope that does clarify, adequately, for your purposes, comparison, or otherwise? And I also apologise to Brendan for the further slight digression away from the OP, but hope it serves to assist with future discussion on this new and confusing technology... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] Last edited by Venomator on 26th Oct 2014 2:42pm. Edited 1 time in total |
@Mjibex
As far as I can tell they change from dipped to main beam. |
Interesting. So are you saying that the measured 1550 lm of the Nolden low beam is an absolutely equal denominator value to the effective 750 lm of the new Speaker EVO2 low beam, or to the effective 650 lm of the Speaker EVO? Measured and Effective are really one and the same common denominator? If that would be correct, then the Speaker EVO and EVO2 should be giving much, much less light than the Nolden. And they are not as we have seen from our comparison test...... Not sure we can take that explanation for its face value. And then, you also say that raw and calculated are one and the same. That and your above assumption that measured and effective are also the same give the following interesting result. Taking low beam as example, the drop in lm with Nolden from 1880lm calculated to 1550 measured is give or take - 18% While the drop from Speaker EVO2's 1770lm raw to 750 effective is give or take -58% That seems to indicate both producers use very different language when talking about lumen. Any electric/lights experts who can clear up this mistery? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Looks like the thread has been split.
Not going to re type what I have just posted on group buy as it is hard work on an iPad. JWSpeaker now uses effective lumens which is a measurement by a photo metric devise So effective lumen = measured lumen. I can only assume that both companies use industry standards for measuring light output. So Noldens have a better measured light output and IP rating then the latest JWS Evo2 Brendan |
Well, I still am not in the clear about all this. I do accept that measured lumen and effective lumen should be different terms for a same common denominator, so both should be showing the real practical output of a LED lamp according to one and the same standard.
Then if Nolden have a lamp with its low beam producing 1550 lm measured, and my Speaker EVOs low beam are producing only 650lm effective (which is supposedly the same as the measured denominator used by Nolden), why in our eyeball test in perfect conditions were both LED lights showing very much the same light production? The lumen difference of the Speaker here are 58% less than the Nolden. I was not alone down there where we did the test, my friend kitoper who has the Noldens came to the same conclusion, and both of us have very good eyesight...... It will be interesting when someone can do a side by side eyeball test of the Nolden vs. the new Speaker EVO2 in a similar controlled environment as we did earlier. With 1550 lm vs. 750 lm, the new Speakers should come out of the test like a candle light..... I wonder what those mentioned "industry standards" really are. Maybe not so strictly defined, and leaving room for interpretation???? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
You really should not try and fill in any blanks, or put words into my response, which are clearly not there, Eric! I was simply trying to clarify the confusion caused by the terminology, which you seemed to be having difficulty with. There is no difference between 'measured' and 'effective', they both refer to the same end result; a physical device reading the output of the finished product in its realised end form. In an ideal world this would be achieved utilising a recognised international standard, using a calibrated photometric device, in controlled laboratory circumstances! However, with LED being a new technology, this methodology may not yet be so perfected. The secondary issues here are: The apparent disparity, as you see it, between the manufacturer's quoted outputs and what your eye sees on the ground in a somewhat unscientific visual experiment, which is fine if that is what you want to use to justify a personal choice. And the seemingly significant difference between the manufacturer's published numbers. The first is relatively easy to dispel, on the basis that the human eye is easily fooled, combined with both the fact the colour temperature of the two light sources is clearly different, together with the less than laboratory conditions your test was carried out in, may easily fool anyone's visual interpretation of the results, into convincing you one, or other light output is better, or the same, as another. That may well account for you (and your friend) being unable to tell the difference between the two light sources you were trying to differentiate between; in effect, your eyes are, potentially, deceiving you! The difference, between the two sets of numbers, from the different manufacturers, is not so readily explained. That is, quite simply, because there is no reference to an international standard, which would serve to indicate they have both used the identical photometric equipment, in the same, controlled, laboratory circumstances. What I would say is that one manufacturer hails from the USA and the other from Germany and we are supposed to believe they are identically E marked. Make up your own mind whether there is any significance in that fact. Interestingly, the USA manufacturer is based in a place called Germantown... ![]() That aside, as a consumer, we should really only start our route to preference using the manufacturer's quoted data from their specification sheets. Their methodology has to be taken on trust, where no international standards are quoted and we, as consumers, must then apply a common sense approach to our choices. In Europe, where standards are, historically, very high and demanding on manufacturers, my money would certainly favour a European based manufacturer in such circumstances, for many and various reasons, not just the obvious. I hope this helps to clarify the content of my earlier response and also dispel any mystery regarding this topic in the current discussion... ![]() By the by - one should not automatically assume respondents are totally clueless about the topic under discussion... ![]() Rog... ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 553 ![]() ![]() |
And with that note, one should state where their knowledge is and why there are to be seen as the greater knowledge base compared to the average person.
If you are that knowledgeable in this field I would be keen to learn more. Eric's test is a good one and while it cannot calculate accurate and statistical results, it goes some way to paint a picture that is different to what is trying to be portrayed here. All that said, I do not like the look of the Noldens and so are not for me. |
Both variants of light are obviosly of excellent quality and it is often the case that human nature will dictate that whatever a person has will 'be the best.'
Based upon my own personal experiences your following quote Venomator has certainly 'struck a chord' with myself.....
As to whether I can agree depends purely upon 'The Jury' if they get the chance to return to deliver their verdict in a few months time perhaps? The first JW Speaker 8700s that were released for the UK market were a vast improvement over standard lighting and the quality and intensity of the light unquestionable for MY needs. JW Speaker were also the first approved LED replacement at that time. As for intensity of the new versus anything else I don't really care as I don't need any more candellas, lumens or Swan Vestas. For me there are only two types worth considering, both contained within this thread. The Noldens haven't been around as long and feedback will naturally be limited and customer base smaller at this time. Irrespective of light output comparability.....IP69K is better than IP67 in any damp environment..... Time will tell if the Noldens can hold their own and if the JW Speakers have indeed been able to improve on what was already a good product. Taste or functionality?........ ![]()
Ironically enough someone in the following link went for the Noldens as they preferred the light output and construction of them over the JW Speaker and Trucklites..... http://pointedthree.com/disc/forums/showth...mp;start=1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Only want to add one last comment here after reading venomator's fairly opinionated last post.
We still may be down to comparing apples with pears here as there are no clearly established international standards (like DIN for instance) referred to by either of the two brands in question for their published lumen numbers. So until we would know that both companies use exactly the same common denominator, i.e. identical testing and reporting variables, one has to remain careful in using those lumen numbers to proof that one is better than the other. Basically until someone, ideally Nolden and Speaker themselves, confirm that they use the same testing/reporting standards, the comparison of the Nolden lumen number with the Speaker lumen number just means nothing at all for trying to proof that one is better than the other. The numbers as we read them are just numbers, not related to a clearly specified one and the same standard. If there is first hand explanation which proofs me wrong I will be the first to accept that here. So for now I think that our eyeball test actually has more value than these numbers. We did a test of both side by side in relative darkness, so in identical conditions, and while I do not disagree that the human eye is also not absolutely perfect, looking at the pictures taken by one and the same camera showing that both products light output is pretty much the same confirms that one is not really throwing out much different amount of light than the other. The differences are minor, a bit different whites, one having a bit more of a hot spot than the other, but otherwise, as we already concluded in the eyeball test, it comes more down to personal preferences about the looks than anything else. Except of course for the IP ratings, which are tested according a clearly accepted standard, and higher is indeed better. Not going to enter into discussion about the USA versus Germany argument, as not even sure if the Nolden are really fully manufactured in the latter country, given Nolden partnership with Microlights, Taiwan (as you can read on the Nolden website). http://www.noldengmbh.de/en/company/business-partner I am sure that in either of those three countries the knowledge exists to produce top quality products. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 30th Oct 2014 5:56pm. Edited 1 time in total |
