Home > Technical > Defender 90 (2004) TD5 - Front Hub |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Fairly straight forward but you'll need a 52mm socket or box spanner. As long as you get all the parts (or just buy a kit) then it shouldn't take you more than an hour or so to do. I'd do both sides though to be sure.
K9f will probably be along soon with some links to follow...... |
15th Aug 2014 10:01pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
Cheers Lambley.
I take it the 2004 doesn't have spacers ? Haynes manual a bit confusing ? Duncan |
15th Aug 2014 10:05pm |
Waiting for K9f Links ?
16th Aug 2014 9:07am |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
Click on the link to my blog at the bottom of this post. Got to "front hub seal replacement" and I've linked to an excellent YouTube tutorial. http://defender90xs.blogspot.co.uk/
16th Aug 2014 11:17am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I would change it to the older system without spacer between the bearings and 2 nuts with a lock ring. Works better I think. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Aug 2014 11:53am |
Cheers Roel,
I will stick with standard for now as is it not a bit of work to change to old ones ? Duncan |
16th Aug 2014 7:32pm |
Is a 52mm 1/2 socket with a breaker bar enough to get the nut off ? When putting it back on will I get enough torque from a normal torque wrench ?
Cheers Duncan |
16th Aug 2014 7:50pm |
52mm 3/4 socket with a breaker bar 150ibf.ft or 210Nm torque |
16th Aug 2014 8:35pm |
No in fact it is less work than the new standard with the spacer in the middle as you probably need multiple spacer and try to find the right one to get the right bearing play. With the old system with no spacer you tighten the first nut, loosen it a little and then tighten it to the right play/resistance. then you put the lock ring and the second nut and tighten it. bend the lock rig over and ready. No mayor other parts needed just instead of the lock nut 2 flat nuts and a lock ring. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Aug 2014 9:10pm |
I thought if I replaced everything I could use the spacer provided with the kit ? And this would give the correct float. ? Damn ! This is proving to be harder than I thought ? So a 3/4 inch socket then ? Might take it to a garage ! Scared now |
16th Aug 2014 9:19pm |
Also are the brake calipers held on by a 12 corner hex bolt ?
Help ? |
17th Aug 2014 10:21am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2692 |
If you use new decent (i.e. Timken) bearings chances are you won't need to change anything as the spacer is set by the tolerances in machining the hub and the bearings are made to tighter tolerances than that. However you will still need to check and be prepared for the fact that it could be out.
To change to the older system you just need to get the two lock nuts and the locking and thrust washers with your new bearing and set it up as normal. Have a look through an older parts manual and you'll see what's needed. Calipers are a 12-point bolt, not hex. Should be Loctited. |
17th Aug 2014 11:04am |
The used set is the newer system, the new set is the older system. Is it clear what I am saying as it sounds strange.
Click image to enlarge Click image to enlarge Click image to enlarge I will reused the plate that is between the bearing and the locknut off the newer system. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
17th Aug 2014 11:25am |
Cherrs Roel.
Gone for 2004 bearings with spacer. Retroanaconda, will reuse the spacer and see how I go ! Fingers crossed |
17th Aug 2014 2:45pm |
