Home > Technical > Defender 90 (2004) TD5 - Front Hub
Page 4 of 4 <1234
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
You can srew a bolt in the half shaft and pull it out.
They are important as they make sure that the CV joint is exact the right position. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #353160 22nd Aug 2014 6:54pm
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
What size bolt ?
Post #353161 22nd Aug 2014 7:04pm
JWL
You can use one of the hub flange bolts which although aren't quite the correct thread, when screwed in by hand give you enough purchase to pull on the shaft.
Post #353166 22nd Aug 2014 7:32pm
Tank
All done.
Bit of a faff but done.
Had to take the hub back off and when I did the staked nut stripped some of the threads on the stub axle !
It's all gone back on ok so lets wait and see how it goes .
Enjoyed doing it, doing the bearings was fun.
Cheers and thanks ever so much for all the advice, very much appreciated.
Great forum really helpful
Duncan
Post #353188 22nd Aug 2014 10:04pm
Page 4 of 4 <1234
