Home > Maintenance & Modifications > Air box mod and decat
Page 9 of 11 <123 ... 8 91011>
Across the range I'd have thought? KEEP CALM AND Drill ON
Post #315138 10th Mar 2014 9:56pm
munch90
as revs go up air volume drawn in goes up , so a restriction in the air pipe should only have a effect in upper rev range . but what revs ?
Post #315142 10th Mar 2014 10:00pm
landybehr
Just FI:
http://en.wikipedia.org/wiki/Hagen-Poiseui...s_notation
that equation relates to fluids. But as an approximation (no more) one can think about air with it.
Flow rate is "Q" and therefore the bigger, the higher the revs. Impressively important is the diameter of the tube - as it counts in the 4th degree ("r^4").
But more important Smile any thoughts about the heater-air-box ? Smile!!
Post #315157 10th Mar 2014 10:30pm
munch90
on a rhd defender there is no heater intake on the side of engine air intake
Post #315159 10th Mar 2014 10:36pm
Anderzander
Can anyone tell me what the standard inlet pipe size is on a Td5 airbox please ?
Post #326919 29th Apr 2014 8:13am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Its always got me, the length of the pipe affects it too.
Why don't we make adaptors to fit a cone inside the air box and drill some holes in the front face of the box to reduce the heat soak and let plenty air in. Surely the heat soak would be similar to the plastic pipe running (albeit a big far) close to the exhaust. I don't go dunking in water much so have no real need for the inlet to be on the wing.
Even better purchase another lid and remove the top out of it for the air and then you have two lids a sealed waterproof one and a 'high performance' one Wink William
Post #326922 29th Apr 2014 8:32am
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi guys.
thanks for everybody who have contributed to this thread,particularly tatra805
I have replaced the factory pipe with 3" pipe and the airbox received a treatment with soldering iron with the Propeller thing removed.
outcomes are:
my puma is definitely louder with mantel steel snorkel. but this is likely due to the relocation of air entry point (near my head!)
there could be some performance gain but I don't really care. All I want is no water in the airbox, after I realized the facotry setup can even protect you from splashing... (yes, I found some water marks in the airbox after washing the fender in a puddle
Martin
Post #335156 2nd Jun 2014 1:52am
It's worth while doing, I am wondering what the mpg differences are though..
Post #335190 2nd Jun 2014 9:34am
theorangebandit
My mpg doesn't seem to have changed much but then my driving style doesn't allow for mpg changes as I simply drive my truck. I do 70 on motorways and I over take using speed.
My induction mod has given me a better feel for the engine better response on throttle and less judder in gear changes. I'm sure I get a better torque range as pulling away in 2nd is much smoother since the mod too. Recently added a silencer centre pipe replacement within straight through which has also increased the smoothness of gear changes and slightly believe it or not quieter engine note
I will how ever mod my mod in the future instead utilising the wing top for the snorkel entry as a four inch pipe is a little too big for the gap above the steering column and it has rubbed a little. So my next mod is to create a Southtown style snorkel and make a new air box that will take the older style cylinder type filter cartridge this again will be sealed and will include some dorm of silicone Hosing
Post #344174 10th Jul 2014 6:37am
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Apologies if I have miss understood....
I thought of this YouTube channel which test out cold air intakes which is quite interesting. (Guess my defender is a factory made racer Rolling with laughter )
No down sides to doing this mod on a td5 rhd? Any water "baffles ect" I would lose and make my engine more vulnerable? Range Rover p38 4.6 99 lpg(gone Sad )
Post #344253 10th Jul 2014 2:12pm
Stue5
Sorry for got to add the link! Embarassed
Post #344254 10th Jul 2014 2:14pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Has anybody managed to replace the air intake from the wing to the air box with a larger one on a td5 with abs?
Or do any of the tuners do a kit ?
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #345020 13th Jul 2014 8:58pm
JWL
I keep looking at mine with the amount of room there is down there and keep thinking about changing the snorkel to a military type one that goes into the engine bay through the wing top blank plastic cover and bypass the lack of room issue.
Post #345028 13th Jul 2014 9:42pm
LandieG
what size is the tube at the airbox? (sorry dumb-ass question, but my truck is in the paintshop being bling'd otherwise I'd measure it!)
I am looking at joining this:
http://www.ppcages.com/?page_id=194
via something like this:
https://www.devon4x4.com/d44-snorkel-adapt...wards.html
to the airbox....
was thinking all 76mm (3") tubing, silicon +/- alloy for the straight bits
any hints / tips for this?
G
Post #514973 16th Mar 2016 4:28pm
geobloke
Ha funny. I was just drawing up an adapter like the D44 one... Jes... How much?????? Mating it to a mantec plastic RAI and safety devices roll cage.
Such a pity no one does a safari-like RAI to fit wit roll cages.
Post #514995 16th Mar 2016 5:40pm
