Home > Maintenance & Modifications > Air box mod and decat
Page 2 of 11 <123 ... 91011>
bell-auto-services
As seen the largest problem area is as Ian says the first part of the intake from the wing to and including the "Post cyclone Dad exit".
We hope to have ready in the first half of this year a new injection molded replacement air intake that ocvers this part in a larger diamiter than as seen here to solve this problem. We may also have a full new air box injection molded cost depending that offers a direct replacement and still uses the factory filter.
This will be compatable with ABS and non ABS cars as well as cars with or without snorkles.
Pete
Post #297214 9th Jan 2014 4:41pm
martinfiattech
Just a question, I plan to have mine remaped, de catted, etc when the warranty runs out in 6 months time. Can you get away with a k&n cone filter fitted to the air mass meter and do away with rest and return to factory spec if going anywhere wet etc. As ive done this to my diesel Vectra (fitted for last 8 years) and it was a lot quicker from idle to 1500 rpm when the turbo joined in, or can this damage the air mass meter as I was told by the man who sold me the filter for my Vectra and its still on its original air mass meter 13 years later advice would be nice and has anyone fitted a k&n to a puma. And done away with all the piping
Post #297795 11th Jan 2014 2:47pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I would think that would be alright. It was what i was planning to do or cwap out the bottom casing for one with holes in it and change as required. My past focus rs had that and they just let them lie. William
Post #297809 11th Jan 2014 3:44pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
So by removing this
I have increased the torque by 11Nm? That's got to be the cheapest mod ever!
Post #297945 11th Jan 2014 9:17pm
rustandoil
Do these mods apply to TD5 ?
Post #298007 12th Jan 2014 7:55am
theorangebandit
Why is there a stupid fake fan in my induction! Thats it I know what im doing when my truck gets back from paint work (warrenty corrosion approved Smile)
Post #298010 12th Jan 2014 8:05am
Porny
Site Sponsor
Yes.... IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #298014 12th Jan 2014 8:20am
Porny
Site Sponsor
borderterrier wrote:
So by removing this
It's gives the potential of 11nm with other modifications to the inside of the air box... especially to the internal trumpet.
However it will never give more max torque than the engine one calibration is set to give. But will aid engine performance and response over the whole rpm range... and thus help it to make max torque. IRB
Post #298018 12th Jan 2014 8:40am
borderterrier
So a large diameter pipe linking the dirty side of the air box to the blank (heater air intake)!on the top of the drivers wing would not only raise the air intake, but also address the restriction of air travel? Not sure if that's physically possible though given the lack of space under there,
Post #298019 12th Jan 2014 8:50am
Porny
Site Sponsor
I'm not a massive of fan of cone filters as half the time they are badly fitted and do nothing more than absorb the heat from the engine bay.
Properly done, isolated from the heat of the engine and fed a good supply of cold air supply you can get some gains....
But to get the best from it you would need a matched calibration/remap to make full use of the changes to the air path set up... just fitting and hoping for the best usually doesn't give any big gain - apart from a placebo effect.
Also careful consideration must be made to MAF placement.
Ian IRB
Post #298021 12th Jan 2014 8:57am
Porny
Site Sponsor
My Defender (running my uprated air intake) uses a 102 mm pipe between the wing intake and the airbox. It's big enough to get your arm up lol.
Ian IRB
Post #298022 12th Jan 2014 8:59am
theorangebandit
I have considered linking my induction to the wint top. The only issue ibe found is the induction pipe for the heater intake turns the opposite way. I may toy wirh the idea further when I get my truck back and start playing with the ibduction
Post #298023 12th Jan 2014 9:00am
borderterrier
Ian
What sort of pipe do you use Ian?
Post #298024 12th Jan 2014 9:01am
rustandoil
Porny wrote:
Yes....
Excellent! A bit of Dremel action soon Thumbs Up
Post #298026 12th Jan 2014 9:05am
Porny
Site Sponsor
It's a silicon based thin wall wire reinforced pipe....
Ian IRB
Post #298028 12th Jan 2014 9:14am
