![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Thank you
Gave it a bit of a wash, polish and wax this week so it looks a bit shiny and also finished tinting the back three windows today just as a stop gap till I save my pennies for masai ones probably next year.
![]() Click image to enlarge Also fitted none rusty tow bar and rear crossmember bolts so it looks a little tidier! Cheers for looking Ray Last edited by mk1collector on 11th Sep 2017 4:09pm. Edited 1 time in total |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 ![]() ![]() ![]() |
Cool looking defender, ray.
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Looks proper mint!
Right I'm now on catchup!, |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
now get them alloys painted black!!!
![]() my youtube channel |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 ![]() ![]() |
Looks very good, id do the wheels black as above or at least change that center cap
![]() Im considering another defender with silver chequer plate and would want to change it to black as you have done, did you paint it or powdercoat it on or off the car? and wondered how its holding up. Cheers Tom Defender puma dormobile camper |
Cheers chaps
![]() ![]() Ray |
Guess what my next job is when I get some free time this week.
![]() Click image to enlarge Ray Last edited by mk1collector on 10th Sep 2017 10:13pm. Edited 1 time in total |
Are you just doing the fronts?
Yeah, I did the backs last week so it the fronts this week
Did you use the LR ones for the rear? Bit of rubber tube that slides on the coil or did you use pads like the fronts?
Did it make a decent difference? |
Yeah I used the rubber tube bits. Although I did use two on each (one top and one bottom) when it only came with the top from factory, which had gone very hard and brittle. After cleaning up the springs and also replacing the spring retainers (as the originals had both snapped on one side) and replacing the damper top nuts as I found the threads on the nut were stripped by whoever replaced them last
Not great pics but I've been busy doing the first side today.
![]() Click image to enlarge Will have to do the other side tomorrow or during the week then see if it's made a difference Ray Last edited by mk1collector on 11th Sep 2017 4:05pm. Edited 1 time in total |
Finished the second side of the front suspension today but haven't had time to test drive it yet. Only a couple of jobs left to do before the trip now. I've just won a sump off ebay to replace the one that the previous owner had tapped out the sump plug hole
![]() ![]() Ray |
