Home > Puma (Tdci) > caterhams LAST problem!
Page 3 of 15 <123 4 ... 131415>
munch90
bit more info would be handy
did brakes come on as you were moving?
if so fast or slow?
any work been done on brakes lately?
did brakes stay on after you braked?
have the brakes got hot?
all the brakes or one wheel or axle etc?
any noises ?
how hard did they come on ?
Post #342506 3rd Jul 2014 12:45pm
Caterham
did brakes come on as you were moving? first time I'm not sure - started up moved off and noticed within say 10 metres, second it was progressive while stuck in traffic?
if so fast or slow? came on slow(ish) - not like it was going to cause a real danger
any work been done on brakes lately? - no works undertaken on brakes
did brakes stay on after you braked? - brakes stayed on and slight touch of brakes brought them to virtually locking (as I write this I'm thinking oversevo'd !?)
have the brakes got hot? not sure about brakes getting hot but have slight suspicion of yes)
all the brakes or one wheel or axle etc? - I believe it was all brakes
any noises ? - no noises (other than from myself Evil or Very Mad )
how hard did they come on - still able to move ..... I would suggest 80% on ?
Post #342510 3rd Jul 2014 1:13pm
munch90
any vibrations like abs working
are you still driving it or is it off road at moment
if brakes have got hot , the discs normally have a orange look to them
Post #342514 3rd Jul 2014 1:20pm
Caterham
any vibrations like abs working - no not at all.
are you still driving it or is it off road at moment - still using and all fine today and yesterday
if brakes have got hot , the discs normally have a orange look to them - no orange colour to brakes (was looking at discs today and all look fine).
Post #342520 3rd Jul 2014 1:35pm
Caterham
just another thought.
I don't believe this is anything to do with anything but thought I'd mention it anyway. gave the ancillary belt a good squirt of wd40 ( Embarassed )....
could that impact on the brake servo and hence cause some kind of fail safe?
Post #342522 3rd Jul 2014 1:37pm
Happyoldgit
Why are you spraying the belt with WD40? Steve.
http://forums.lr4x4.com
Post #342536 3rd Jul 2014 2:36pm
jimbob7
This Shocked /\/\/\,regardless,for the umpteenth time, WD40 is bad fer rubber. Pov.spec,ftw. 2006, 110,TD5.
Post #342539 3rd Jul 2014 2:40pm
Caterham
Embarassed
to make sure it looks nice and shiney.
always done it Shocked
makes everything sound all nice
what does .... This Shocked /\/\/\, mean or should I not ask.
Post #342540 3rd Jul 2014 2:42pm
smb
WD40 Exclamation Question Exclamation Get that stuff off it asap otherwise you will be Big Cry
Post #342541 3rd Jul 2014 2:47pm
munch90
from wd40 website
What surfaces or materials are OK to use WD-40 Multi-Use Product on?
WD-40 Multi-Use Product can be used on just about everything. It is safe to use on metal, rubber, wood and plastic. It can also be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40 Multi-Use Product.
BUT I WOULD NOT PUT IT ON A BELT THAT YOU WANT TO GRIP !
if I sprayed it and a bit went on a rubber part I would not worry , but I would not use it to spray rubber repeatedly
Post #342542 3rd Jul 2014 2:49pm
jimbob7
WD40 is utter dog5hit,It's way over priced,it cooks like chip pan fat on hot surfaces and turns brown,it rots certain rubbers/plastics,its meh at freeing rusty nuts and it doesn't clean electrical contacts its leaves a thin film of oil which attracts dirt,to clean electrics buy proper contact cleaner.Dunno why you would spray anything on a belt tho,lol?
I would have thort it needs a short to activate the abs/brakes whilst driving maybe start looking for dodgy wiring.
Definitely brakes coming on,not the engine briefly cutting out? Pov.spec,ftw. 2006, 110,TD5.
Post #342546 3rd Jul 2014 3:03pm
jimbob7
munch90 wrote:
from wd40 website
WD-40 Multi-Use Product can be used on just about everything. It is safe to use on metal, [u]rubber[/u], wood and plastic. It can also be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40 Multi-Use Product.
Quite a few people disagree.
https://www.google.co.uk/webhp?sourceid=ch...or++rubber Pov.spec,ftw. 2006, 110,TD5.
Post #342549 3rd Jul 2014 3:17pm
munch90
well if THEY ( and not someone they know ) have had a problem then they should get on the people who make wd-40
but I like I said I would not repeatedly spray it on rubber
Post #342550 3rd Jul 2014 3:27pm
munch90
sorry caterham went of topic there for a while
when brake problem happened first time how did they release , think you said someone came out to you , what did they do
Post #342553 3rd Jul 2014 3:40pm
Caterham
Shocked
Did I mention wd40 and rubber
Laughing
They same as me had a look around the brake pedal because of the suspect brake / clutch switch wiring and heard a click from brake pedal and then all fine???
Driving home tonight all good and I might even go as far as to say it drove best it ever has with what I would describe as perfect rev hang to perform perfect gear changes. Engine was smooth and really responsive.
A very big Thumbs Up just didn't last but brakes still fine.?
Post #342580 3rd Jul 2014 6:30pm
