![]() | Home > Puma (Tdci) > Narrowing down the problem-Overheating |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
I'm no mechanic , hence my difficulty diagnosing the thermostat issue, but I'd say if you suspect thermostat just replace it. It cost me Ł18 or something and it's not a hard job, just a little fiddly. It's down the passengers side of the radiator and you ll find it easiest if you quickly unscrew the plastic fan cover (takes 20 secs honest) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
All tdci's I've driven sit at bang on half way when up to temp Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Whitewaitress Member Since: 26 Nov 2013 Location: Liverpool Posts: 47 ![]() |
Thanks for the advice David, will give it a go!
I'll also feedback what mine does after replacing the stat, after all it may have been running a little hot for a while and just peaked more recently... Cheers, David
Eduardo Member Since: 28 Aug 2008 Location: RegiĂłn Metropolitana Posts: 2110 ![]() ![]() ![]() |
Don't know yet. Now the weather is quite cold and my problem arise with medium-high temps (over 25°C). Anyway I will put the ODB to see the temperature after the change. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thermostat appears to have fixed mine, will keep an eye anyway...
![]() ![]() ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Had coolant temp problems with mine. Overheating. Scanguage showed temps upto 105 whilst instrument gauge sat at halfway, then gauge shot up and limp mode. Radiator stone cold but pipes to thermostat hot. Indi changed thermostat. Now temp gauge rock steady at halfway. Scanguage shows temp varying between 75 and 85 depending on driving type, speed etc. off to the Swiss Alps in 5 weeks.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
^ exactly the same as me, temp now sits at 85 max having been up to 109.3 max before I replaced the thermostat! Cheers, David
Good to hear this has sorted yours David, the needle hardly budged this morning on my drive out to work - something not right there! I'll test the thermostat this weekend but I've now got my suspicions on the cylinder head / head gasket leaking exhaust gasses into the coolant.
Hoping this at the worst is a failed gasket and not a warped or cracked head! |
Surely head damage etc would cause overheating not running cold?
I'd check thermostat- they're cheap and easy to replace, and if it's stuck open then it'll struggle to let the engine get warm if guess (opposite of mine being stuck closed!) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
