Home > My Defender > What Did You Do In Your Defender Today |
Fishmaster Member Since: 08 Mar 2014 Location: Yorkshire Posts: 7 |
Finally got round to sorting the turning circle by adjusting the bump stops. Now I can out manoeuvre the QE2.
28th Apr 2014 9:10pm |
Popped into a dealers in Conwy for some spares, had an interesting looking defender in the yard
29th Apr 2014 8:56pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Popped my 110 in to RCV to have some quotes for some work done.
Came up very very reasonable - waiting on an appointment with Gigglepin before making any decisions but given the standard of there work I have seen am very impressed Also picked up my new seat base foams I ordered from LRI Solutions. Using Exmoor trims own excellent videos Me and my girlfriend had a go at re-trimming my seat bases. Girlfriends seat went first and we did a brilliant job- very pleased. Then full of confidence set about my seat base. It didn't go quite so well. I think it moved while it was glueing and as such has come out a misshaped (I don't think Matt would approve ) What do we think? Click image to enlarge It works as a seat so I'm happy with it which is all that matters |
29th Apr 2014 9:42pm |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 |
Looks like the padding was worn... Looks like it's sagging in the middle... But it's. Or bad...
29th Apr 2014 10:33pm |
Its bad xD
Will have another go at the weekend. |
29th Apr 2014 10:36pm |
At least you didn't do what I did, spray the foam with spray glue whilst in the newly fitted kitchen................that stuff takes on the appearance of flying gossamer spiders webs, very pretty when airborne but such a witch when they land and stick to anything and everything.
That'll be another one of those reasons I'm divorced |
29th Apr 2014 10:51pm |
90mojo Member Since: 19 Mar 2014 Location: UK Posts: 175 |
Received this from Jim at Adrenalin today. Top product, fits perfectly. Jim was very helpful, prompt response and delivery. Well pleased.
30th Apr 2014 4:21pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
fitted tm2 watchdog
Click image to enlarge My 109 thread my youtube channel |
30th Apr 2014 4:31pm |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 |
Intrigued "tm2 watchdog" ?
Martin |
30th Apr 2014 4:38pm |
g-mack: Where did you get that from? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
30th Apr 2014 4:42pm |
Gum, it came from Brendan (leeds) on here.
basically it has a sensor that attaches to any convenient bolt on the engine and gives you instant feed back of the engine metal temp! apparently the standard water temp gauge is slow to react, and often when it does go into the red its to late you've cooked your head! the TM2 can set a temp at which it will warn you once reached. so lets say engine boils at 116deg depending on coolant mix, you may want to set alarm at 102/4 ish to give you plenty warning. that way you can pull over before it cooks! not after like with standard water temp guage!! My 109 thread my youtube channel |
30th Apr 2014 5:41pm |
G-mack, which bolt did you put the sensor on? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
30th Apr 2014 6:15pm |
i put it on the top thermostat housing for now. not sure thats the best place, i wanted to get it nearer the back and on the head if possible but haven't found a suitable bolt yet. there are some bolts on the block which i might try too! was told best not attach to exhaust side as it may be naturally warmer round there! My 109 thread
30th Apr 2014 6:20pm |
Ha, that's where I put mine too, was also looking for alternative positions.
Cheers Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
30th Apr 2014 7:12pm |
