Home > Puma (Tdci) > 2.2 Spin-on oil filter... |
guy.cashmore Member Since: 06 Dec 2013 Location: Cornwall Posts: 17 |
LR Microcat wasn't even showing a price 3 days ago!
11th Dec 2013 8:14pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Dont know about LR suppliers ... But Ford dealers have hundreds now [we use a few every week]
Ford part number - 1812551 HTH Guns and Landrovers .... anything else is irrelevant. |
15th Apr 2014 2:27pm |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
Thread back from the dead...
Picked up a filter today from local LR dealer (not pre-ordered so looks like folk have stock): LR058104. LR Box, FoMoCo filter (as per earlier poster's pic) inside! £12.29 (+ VAT) Oil drain plug (with built in O-ring) L1013938: £3.07 (+VAT). |
10th Jul 2014 9:42pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 737 |
I was wondering why a friend's Defender had a screw on filter while mine had a plastic bowl. Granted that his was a 2.2 and mine is a 2.4, question now becomes, do they have these screw on filters for the 2.4 as well?
26th Jan 2015 6:32am |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 323 |
No, all 2.4 and 2.2 up to vin DA444246 have the element filter LR030778.
The 2.2 from vin DA444247 have the canister filter LR058104. |
26th Jan 2015 7:35am |
but, is the new filter bracket/cooler mountable on the "old" 2.2 and 2.4 ?
MC on line doesn't show the new version..... Thanks to BAS the P/Ns are Oil filter housing/oil cooler assembly From VIN DA444247 Quantity: 1 LR049474 Gutless thermostat Quantity: 1 LR029936 Thermostat (oil cooler) Quantity: 1 PEM100990 Thermostat Quantity: 1 PCF101530 I don't know if we need some new hoses........ I would prefer the "new" filter, easiest to change ...... any comments? if we can do, however, it is an expensive modification, more or less 350-400£ for the parts..... Make sense? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 26th Jan 2015 8:13am. Edited 3 times in total |
26th Jan 2015 7:38am |
As far as I can tell it may be. The ladder frame part of the block which the cooler bolts on to shows the same part no. for all 2.2s. However the block to filter/cooler gasket is different, as is the coolant hose to the cooler.
26th Jan 2015 7:49am |
At home I have a newest MC version (12-2014), I'll check on it.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
26th Jan 2015 8:11am |
2014.12 - same as I'm using
26th Jan 2015 8:18am |
FYI, these are now available non-genuine, we use Mann filters across our fleet, W8027 is the Mann part number and they are half the price of LR or Ford. 5 Land Rovers and a Corsa!
7th Apr 2016 1:22pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
It looks like that filter is new obsolete and has been replaced by W7050.
Still half the price of a LR filter. |
2nd Jan 2020 12:39pm |
