Home > Maintenance & Modifications > Securing an 'ardcase |
Question about this installation. Those screws used to tie down the various supports that hold the belts, do they simply screw out and back in, or is there risk that a bolt or other at the other side of the panel gets dislocated or falls out while the screw is out?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
25th Sep 2015 2:17am |
^^ Anybody know this? You never actually own a Defender. You merely look after it for the next generation.
26th Sep 2015 7:07pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Had a look and they are very easy to access from underneath the vehicle so not really a big issue but will let you know tomorrow when I fit the belts.
26th Sep 2015 7:25pm |
Thanks Steve, but.... I may have to look at alternatives for this, because I forgot that that vertical rear seatbox panel with those screws in my case is fully carpeted from new. Not going to cut the carpet up for this, so have to rethink location. Most practical would be under the second row seats where it would not bother anybody and where it is easily accessible....
27th Sep 2015 4:28am |
twinspark Member Since: 04 Apr 2015 Location: Edinburgh Posts: 18 |
Maybe not "secure" but if you have a 7 seat Puma (assume would apply to 4 seat too) then with a zip up Sports Bag, you can "post" the bag and 'Ardcase into the triangle of the rearmost seats (the bit that moves and which the seat base rests on). Hasn't moved in several thousand miles of driving.
27th Sep 2015 12:08pm |
