Home > Maintenance & Modifications > Air box mod and decat |
MINE!!! Pete ONE FOR ME! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Jan 2014 9:22am |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Would this stuff do the job?
http://www.autosiliconehoses.com/silicone-...etres.html |
12th Jan 2014 9:43am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Yes that sort of pipe Borderterrier.
When I did the one I made as a prototype test wing backing it was from some alloy I had kicking arround to attach the pipe to. As Ian has pointed out, this is fine on non ABS cars but the ABS cars are a little tight for space. Its also very tight next to the alternator bolts on both abs and non abs cars. Click image to enlarge Click image to enlarge Pete Last edited by bell-auto-services on 12th Jan 2014 11:56am. Edited 2 times in total |
12th Jan 2014 11:41am |
Very next. Pete. I was thinking of using the heater intake on the top of the wing though.
12th Jan 2014 11:43am |
Depending on the speed you are wanting to do something im already working on a solution that is an easer fit but it will be some time yet before ready.
The pipe I made above worked very good albiet a bit crude and for sure helped with breathing which lead me to the next project, Injection moulding a pipe from the wing to the air box for ease of fitment, and a new air box that has no restriction inside all as a bolt on fit. These pictures show our unmodifyed drawings we had 3D lazer scanned which will aid us to adjust the restricted areas and have made less restrictive. Click image to enlarge Click image to enlarge Pete |
12th Jan 2014 11:49am |
I think Nakatanaga do something like this as a kit, Ive not seen in in the flesh but have seen pictures. It uses both the side and top vents I beleive. If you do make one your self to add extra air in combined with the side vent do be aware of the wing top getting water in it though, IRB do a snow vent that may help protect against this problem ?? Pete |
12th Jan 2014 12:08pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Not a bad ofea to plum in the top and side vent. Im going to spend some time locating the kit that maybalready exist
12th Jan 2014 1:05pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
Well, 45 mins with a Dremel this morning and i had this
Click image to enlarge |
12th Jan 2014 3:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20314 |
Can you not just take out the water separator thing then? If you can't it's not so easy then.. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
12th Jan 2014 3:40pm |
Steve, do you mean the "fan like" thing? Yes you can but mine did not want to let go and had to be forcibly removed
12th Jan 2014 3:46pm |
Mine was a PITA to remove too.
12th Jan 2014 3:50pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 699 |
Will this not do for the wing top air intake?
http://nakatanenga-tours.de/shop/article_O...DOAITD4%26 2008 Defender 110 XS SW - M57N2 / 6HP28X |
12th Jan 2014 8:37pm |
I suppose it would, but it's expensive. I am going to go for silicon hose 102mm dia and a home made link to the wing top bent. I shall add a snow cowl and bobs your uncle - maybe!
12th Jan 2014 8:43pm |
Wow! I really have no idea wherw people pluck their prices from! Ill be making my own version using all the same materials as Mr borderterrior. Unless I manage to hide in the metal bay at work enough I may be able to make up an nice top spec welded metal intake
12th Jan 2014 8:55pm |
