Home > Maintenance & Modifications > Air box mod and decat
Page 4 of 11 <123 45 ... 91011>
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I was thinking of using a LHD heater intake and some of that piping. Had a look today and it's a very short distance, added bonus is that it raises the height of the intake and makes it into a true snorkel, assuming I seal it correctly. Very Happy
Post #298204 12th Jan 2014 10:01pm
bell-auto-services
carrotbay wrote:
Will this not do for the wing top air intake?
http://nakatanenga-tours.de/shop/article_O...DOAITD4%26
That's the picture I seen Smile I tried to find it on their site today and couldn't Big Cry
Post #298208 12th Jan 2014 10:09pm
theorangebandit
Haha dont feel ashamed I too did not locate the nakantnenga kit.
I have noticed the beauty of the short distance between the wing top and the air box. Means that theres evwn less risk of adding a restriction. Ill certainly need a second snoe cowl. Infortunately I want an ex mod metal one to match the one im soon to fit on the heater induction side
Post #298212 12th Jan 2014 10:13pm
dgardel
Italy
bell-auto-services wrote:
Depending on the speed you are wanting to do something im already working on a solution that is an easer fit but it will be some time yet before ready.
The pipe I made above worked very good albiet a bit crude and for sure helped with breathing which lead me to the next project, Injection moulding a pipe from the wing to the air box for ease of fitment, and a new air box that has no restriction inside all as a bolt on fit.
These pictures show our unmodifyed drawings we had 3D lazer scanned which will aid us to adjust the restricted areas and have made less restrictive.
Pete
Pete,
mine have not the ABS and it is LHD! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #298225 12th Jan 2014 11:16pm
bell-auto-services
dgardel, could you please get me some under bonnet pictures of the LHD standard intake ?
Post #298272 13th Jan 2014 9:54am
dgardel
Italy
Pete,
I'm in Kuwait until January 23.
When I return I will be happy to make you photos, can you wait? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #298274 13th Jan 2014 10:04am
bell-auto-services
No problem, ill see if i can get some in the mean time,. if not it can wait.
pete
Post #298278 13th Jan 2014 10:11am
dgardel
Italy
meanwhile Mr. Green
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #298280 13th Jan 2014 10:24am
dgardel
Italy
first pics of my engine
IID Pro MV License
Post #298291 13th Jan 2014 10:49am
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
The intake is the same but unfortunatly much space is occupied by the heater air intake,the hose from the fender grill to filter box has to be very flexible to go under the heater intake Evil or Very Mad
Please do your best,i can't wait for another(decent) filter box!
Post #298637 14th Jan 2014 11:22am
fatman
Just took some pics of the LHD setup..
And one from underside..
Post #298723 14th Jan 2014 3:46pm
bell-auto-services
Thank you for the pictures, that does look tight on the LHD Big Cry
Pete
Post #298974 15th Jan 2014 9:18am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
But surely there will still be more space than a RHD non ABS motor as they fit the webasto heaters in there.
Fair enough they have to take the wing off to install it Rolling Eyes William
Post #298985 15th Jan 2014 10:21am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
this is what i have done as posted earlier
http://www.defender2.net/forum/topic17821.html
Smile
Post #298986 15th Jan 2014 10:21am
fatman
Since i already have a mantec snorkel (metal tube one,attached to the roll cage),i'll follow your solution,otherwise i would use the top wing grill for air intake and an old style snorkel(from top of the wing) and would use the side grill for heater..
Post #299005 15th Jan 2014 12:01pm
