Home > Maintenance & Modifications > DRL bumper fitted (thanks Killer90)
Page 3 of 3 <123
Killer90
Site Sponsor
Glad your happy Thumbs Up is it ok to pinch the photos for the website David Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #294450 30th Dec 2013 11:41pm
Cheshire110
Yes, certainly if you wish! Cheers, David
Post #294452 30th Dec 2013 11:45pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
There is a 2 way relay, has 5 contacts that will switch from one circuit to another. You have main power in going to DRL. So DRL's are on when power is applied. When side lights are switched on then relay switches power to circuit 2 which is connected to NOTHING. So DRL come ON with ignition and go OFF with sidelights. Simple. I presume if you just wanted them to dim with sidelights then a suitable resistance in Circuit 2 and connect to DRL would do the job. Ignition ON - Circuit 1 active - Full power to DRL. Sidelighta active - Circuit 2 active with resistance - 1/2 power to DRL.
I just have them switch off with sidelights on.Passed it's MOT with no problem. Tester was interested as to how it was set up. Thumbs Up Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #294466 31st Dec 2013 6:51am
Cheshire110
You may be able to help me?
I've fitted my DRLs as you can see and would just like to be able to dim them when a circuit comes on (sidelights in this case)
Does an LED dimming relay exist?
I don't want the voltage sensing bit though... Cheers, David
Post #297399 10th Jan 2014 12:05am
Cheshire110
Ah, ok good!
I'll buy one when I get back from uni
Thanks Cheers, David
Post #297438 10th Jan 2014 8:56am
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
I've been looking into making a loom up to meet my own requirements, I want my drls to illuminate when locking and unlocking, to come on when the "ignition" is on position 2, go off or dim when the dip beam is on and ideally dim the corresponding side when the indicator is flashing (like Audis).
I've done a little research and come up with a quick sketch of how I think it will work. It will basically comprise of 4 relays some diodes and 2 Pulse-width modulation dimmer switches (apparently led lamps don't like resistors). I plan to build it using traditional relays and wire it up but If it works ok I can't see why it can't be made with micro relays on a printed circuit board.
So cast your eyes over my sketch and I would be most grateful if any of the electrical gurus could give any additional advice as I'm no expert.
 Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #297589 10th Jan 2014 5:49pm
Captain Speaking
2008 Defender 90 Puma 2.4 CSW Tonga Green
Very Happy
Post #474237 19th Nov 2015 3:58pm
VeeTee
Netherlands
(Re-)read Go Beyonds' reply - this the correct way to wire them in with auto on/off AND your requirement to turn them off manually. Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #474251 19th Nov 2015 4:21pm
Page 3 of 3 <123
