Home > Maintenance & Modifications > DRL bumper fitted (thanks Killer90)
Page 2 of 3 <123>
Why not get the installer to wire it properly ?
Post #294365 30th Dec 2013 10:16pm
Cheshire110
Because I'm the installer haha!
And didn't fancy them being forced on by the engine and me not being able to turn them off (as the police car needed to do in the above example!)
Does such a relay exist? Cheers, David
Post #294367 30th Dec 2013 10:20pm
I'm sure it does but not sure it would work with LEDs
Post #294368 30th Dec 2013 10:22pm
Cheshire110
GEllis wrote:
Mine dim to 50% when sideghts are switched on.
What dims them? Do you have a unit that does it?
I don't fancy the voltage sensor thingy though, just want it to dip with sidelights Cheers, David
Post #294369 30th Dec 2013 10:26pm
excossack
Wire them in as they should be and maybe put a switch in so you have auto on (as they should be) or off. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #294370 30th Dec 2013 10:27pm
Cheshire110
Yeah I did briefly try that but the auto on unit doesn't work with a 12v feed from the switch. It needs a straight feed from the battery which would require a lot of effort and wouldn't be protected by a fuse etc
May just live with switching them off/on when I need them!
Ideally there would be a simple 'LED dim' relay... Cheers, David
Post #294371 30th Dec 2013 10:30pm
ericvv
GUM97 wrote:
Quote:
I however didn't use it, I just wired it through and on/off switch which I already had wiring at the front for. I like to be able to turn them on/off whenever I like.
I'm not sure the MOT man will like that! We've had a vehicle fail for exactly that reason, as according to the UNECE (regulations 48 and 87) they are incorrectly sure and could be used at night time, thus dazzling other road users and causing an incident. Rolling Eyes Bloody EU!
(Btw, we're currently discussing the matter with VOSA head office, and appealing the failure!)
Here is an extract of the current EU regulations concerning DRLs (E/ECE/324 E/ECE/TRANS/505 } Rev.1/Add.47/Rev.6)
On page 73 you can read this...
QQ
6.19.7.1. The daytime running lamps shall be switched ON automatically when the device
which starts and/or stops the engine is in a position which makes it possible for
the engine to operate. However, daytime running lamps may remain OFF while
the automatic transmission control is in the park or neutral position, while the
parking brake is applied or after the propulsion system is activated but the vehicle
was not set in motion for the first time.
The daytime running lamps shall switch OFF automatically when the front fog
lamps or headlamps are switched ON, except when the latter are used to give
intermittent luminous warnings at short intervals.
QQ
In a nutshell, they have to come on and switch off automatically as above, not manually via a button.
Mine are wired to come on with the contact on, go off automatically once turning the parking lights or low or high beam on. But they remain illuminated when without any lights turned on I give a high beam warning signal. That is the correct way, including for Switzerland where our MOT equivalent took the pleasure verifying if the installation was correct. And it was indeed. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #294372 30th Dec 2013 10:32pm
GUM97
Something like these ...?
http://www.fordownersclub.com/forums/topic...es-or-drl/
http://britelightleds.co.uk/index.php?rout...#container An engine to TDi for!
Post #294376 30th Dec 2013 10:35pm
GUM97
Eric- Thanks for posting that, it clarifies the matter nicely Thumbs Up An engine to TDi for!
Post #294377 30th Dec 2013 10:37pm
ericvv
GUM, I am by no means keen on this kind of legalistic documents, but sometimes they come in handy. So for those having questions or doubts, here is the fully Monty of the EU lights regulations, I believe this revision 6 is the up to datest version. Re DRLs look on pages 72 and 73.
Happy bed time reading Laughing
Eric
https://www.defender2.net/gallery/albums/u...proval.pdf You never actually own a Defender. You merely look after it for the next generation.
Post #294378 30th Dec 2013 10:47pm
Cheshire110
It's annoying all the DRL controllers you find use a voltage sensor to trigger the on/off by sensing the alternator voltage or batt voltage (~13.5V vs ~12v) but I don't want that..
The voltage sensors don't work with a 12v ignition feed, they need straight from the battery which I don't have a feed at the front for. Therefore they won't ever come on, sensing only ever 12v
Ideally need to find just a relay that dims an LED when a feed triggers it, but never seen such a simple one. Cheers, David
Post #294381 30th Dec 2013 10:58pm
Why not wire correctly to the battery positive through a fuse and then switch the earth for manual off control
Post #294383 30th Dec 2013 11:00pm
Killer90
Site Sponsor
Thumbs Up Glad your happy David, looks great fitted Thumbs Up Just to clariffy this is one of our new design custom made 5mm thick flush fit D.R.L Bumpers which allows the drls to also be adjusted if needed. cheapest price out there for such quality to Forum members Thumbs Up
Appreciate the write up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #294384 30th Dec 2013 11:01pm
GEllis
England 2013 Defender 110 Puma 2.2 USW Indus Silver
David, from your initial post you said you had another wire you did not use, I would guess this needs to be connected to the side lights and the unit will dim the lights. You could then switch the positive allows you to have them on or not.
Post #294389 30th Dec 2013 11:06pm
Cheshire110
Yeah it's really good Killer, cheers. The bumper has fewer mud traps than the factory one too! Smile
And GEllis it came with a voltage sensor as are easily available on eBay, but I don't like them. They often don't seem to work and they don't work with a 12v ignition feed but only a direct battery feed. I could've used this as it also incorporated a 'turn off with the sidelights' function but as I've said I don't want to have to rewire my wiring and switch to use the battery
Again, ideally I just want a relay to dim my LEDs with the sidelight feed (no auto on/voltage sensor function) Cheers, David
Post #294396 30th Dec 2013 11:17pm
Page 2 of 3 <123>
