![]() | Home > Puma (Tdci) > Puma Engine Issues |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
The squealing noise is most probably a leak from the pipe from turbo to intercooler. Check for abrasion damage from the steering components (a common problem with the 2.4).
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Have a read of this post I did on another forum, (saves me writing it all out again.
![]() http://www.aulro.com/afvb/90-110-130-defen...turbo.html It could very well be a leaking boost hose but does the squeeling coincide with boost demand and what psi does the squeeling start at?? HTH. ![]() |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
The squeal noise is when I want to accelerate. So I guess when I want an increase in boost. Don't have boost gauge so don't know what PSI. At full speed there is no noise. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Most diagnostic tools allow the monitoring of live data which will include the boost psi.
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
while on engine issues, anyone got any idea what could cause this?
its a 2010 2.4, 48k miles when like overtaking in 5th / 6th gear you put your foot down and the car will start to accelerate then 3-4 seconds after the engine looses all power, then picks up again... goes on and off like this |
What is the engine revs and vehicle speed when this happens? Has the speed limiter been removed through a remap?
still limited to 82 and id say approx 2000 - 3500?
not to sure the cars having its 48k serv and a few other bits and bobs, have mentioned it to dealer but they never told me they found out and are yet to give it a test drive |
Sounds to me the exact symptoms of you hitting the limiter and/or the engine is 'overboosting' another symptom I had with my old remap, ultimately you will need a diagnostic run/fault reader to see exactly what's going on. If you go through life with your head in the sand....all people will see is an ar5e!!
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
I have experienced similar - it all came down to gasket between turbo and manifold.
Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
vodonos Member Since: 13 Jan 2013 Location: CERKNICA LAKE Posts: 29 ![]() ![]() ![]() |
I have similar symptom with water in fuel filter
Best regards BOŠTJAN SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
I may have solved this problem....
The engine lost power again. I stopped with the engine running and opened the bonnet. I was looking at the electrical connectors and checking they were fitted correctly and secure. When I touched the one on the front of the fuel rail the engine hiccuped. When I touched it again it hiccuped again. I switched the engine off and unplugged the connector and it looked ok but was under tension from the loom. I adjusted the loom slightly so the connector was not under tension and the problem has yet to re-occur. I also slightly adjusted one of the female connectors in the plug as it did not look like it was making as good a connection as the other connectors. Is it likely that this connector being loose could give me the symptoms previously described? 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
