Home > Puma (Tdci) > 2.2 Spin-on oil filter... |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
Are you sure there isn't one from a different vehicle that fits?
(Would be very surprised if there wasn't) |
20th Nov 2013 9:02pm |
Rick81 Member Since: 08 Sep 2013 Location: Wiltshire Posts: 102 |
Maybe, but it is now a warranty question as apparently it is not just a question of one which fits but one that meets the required specification...
20th Nov 2013 9:32pm |
Indeed, but my money would be on there being a suitable alternative out there (there aren't a huge number of oil filter makers). Most likely a Ford type given the engine's origins?
I take it the dealer is proposing swapping the housing as a warranty job? |
20th Nov 2013 10:07pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
not so much warranty but a recall 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
20th Nov 2013 10:18pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2755 |
maybe not such a bad thing if you can actually find a filter!
the push&twist ones are Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
20th Nov 2013 10:23pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 659 |
Why did they start the oil change if the parts were not all there in stock?
I assume they decided not to charge you- yes? Cheers Steve |
21st Nov 2013 10:24am |
Ford Transit (MK7) TDCi!!! for sure Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
21st Nov 2013 10:51am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
I service 3-4 Transit 2.2/2.4 TDCI's every week .. all 2011/2012/2013 ... never seen one with a spin on filter cannister - they all have the same bowl and paper element as previous models Guns and Landrovers .... anything else is irrelevant.
21st Nov 2013 1:08pm |
LR (now LR004459)
Ford (Motorcraft) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
21st Nov 2013 1:18pm |
Yep, they are the current [and previous] filter element.
But rick81 says his vehicle is not fitted with this type, but a spin on cannister type ............ Guns and Landrovers .... anything else is irrelevant. |
21st Nov 2013 1:56pm |
Do you mean by spin on filter the filter that could perhaps go on the top of the engine I know some 3.2 engines I had had a spiny filter like the old td5 in the rocker cover cup holder 2015 2.2 tdci hardtop xs
21st Nov 2013 2:26pm |
Hi everyone, to be clear mine is fitted with a spin on filter like the old Tdi and V8 petrol engines were, not the element type that everyone thinks are current....
The dealer thought ( ) that they had the right filter in stock, what was not very good was that they then put the old and damaged filter back on. The lady at reception told me that it was fine "they have a seal you know" and "I will chase it up next week" and yes they did still charge me full whack. When I got home and saw how badly damaged the filter was I emailed a very detailed complaint and stated that I intended to call land rover assist stating that my filter was damaged and leaking and I felt the vehicle not drivable..... Service manager on the phone explaining/apologising, had it collected this morning and a double cab demonstrator delivered for me to use (I was offered a range rover but said if I had wanted one then that is what I would have bought...). |
21st Nov 2013 6:37pm |
Does anyone have an email address for LR customer services by any chance?
24th Nov 2013 2:46pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
On here. Dedicated Forum group.http://www.defender2.net/forum/topic24642.html LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
24th Nov 2013 3:52pm |
