Home > Maintenance & Modifications > Headlamp upgrades
Page 3 of 5 <12345>
theorangebandit
adafish wrote:
theorangebandit wrote:
Yea I aligned mine I use a rather crude method to align land rovwr lights where I take two paces back from the bumper and line up the flat beam with my belt line.
Dditivesip beam
Main beam
What happens if you dress like Simon Cowell ?
Dont get it?
Post #278021 30th Oct 2013 1:41pm
barbel jim
Trousers pulled up to your ears Whistle
Post #278026 30th Oct 2013 1:48pm
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
I changed 2 weeks ago to the Nolden LED headlights , you can't compare them with anthing else .
My wife said , why didn't you got them sooner ... Mad
I know there not cheap , but worth every penny ... [/img][/url] Postmanpat
Post #278038 30th Oct 2013 2:56pm
moresauce
Having read this thread I'm just going to order a pair of Wipac crystals. On the bulb front I'm going to go for Osram Night Breaker Plus bulbs based on this recent bulb test
http://www.autoexpress.co.uk/accessories-t...lamp-bulbs
Post #278115 30th Oct 2013 8:14pm
Mountain_man
Wales
ppad wrote:
Hello experts,
While you are talking headlights ...
I am about to a) drive a German BMW to the UK and b) drive my UK TD5 to Switzerland for it to have a few months R&R in the winter there.
So, what are the current rules and regs about dipping in the right (or left) direction? Question
I have been in Oz for 23 years and am not up to date with EU and country rules, I don't want a 100 Euro/S Franc/quid fine every time I cross a border.
Thanks.
(I guess I should think about -20C and how to prepare for it.. are there any old posts about that?)
Just use a bit of black tape to cover the up-swept part of the dip pattern on the front of the lamp unit and you will be fine.
Post #278176 30th Oct 2013 10:26pm
Mountain_man
Wales
And with regard to this topic. On any pre puma defender you will never see the full potential of any lighting upgrade until you upgrade the wiring. It is a simple DIY job for most people and will make even your bog standard lights work better than you ever thought possible. IMHO it should always be the first upgrade to the lighting and not the last.
Post #278178 30th Oct 2013 10:29pm
Which bulb is now generally classed as the best, I have Philips Extreme in mine. Very good but I find the cut off point of the light is not great but that might be alignment TheThunder Rolls🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #278186 30th Oct 2013 11:38pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
[quote="Mountain_man"]...pre puma defender you will never see the full potential of any lighting upgrade until you upgrade the wiring .... it should always be the first upgrade ..
Sort of makes sense, but you are the first to suggest this .. upgrade to what spec wire (and why is TD5 wire inadequate?)
Question
Thanks for the note about simple masking tape. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #278228 31st Oct 2013 9:17am
Postmanpat
know people that upgraded the wiring , may help but doesn't realy shows a difference ... Postmanpat
Post #278230 31st Oct 2013 9:26am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
“a) drive a German BMW to the UK and b) drive my UK TD5 to Switzerland”
Your UK vehicle will definitely need modification: if standard LR headlamps, a bit of Fablon-type sticky cut to shape as suggested above definitely does the trick, if you’ve high-intensity, i.e. high-heat jobbies, I wouldn’t risk adhesive damaging the plastic lenses.
One would hope that a BMW’s lights wouldn’t be silly enough to dip to the right and blind UK drivers… European cars can mostly be switched to dip from one side to the other, or dip up and down.
But “why should we bother to change our headlamps, the Frogs don’t when they come over here” sells a lot more copies of the Daily Mail.
Peter
Post #278245 31st Oct 2013 10:47am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Brendan: how do you find the JW lights compared to the Noldens? This is on just those being the light source (ie not with other added spotlights etc)
Post #279353 4th Nov 2013 1:43pm
leeds
Hi Diablo, both Barbara and I prefer the Noldens over the JW Speaker. We have a set of each fitted to our two company Land Rovers.
When it comes to main beam there is a big difference between the Noldens with its greater range and light output over the Speakers. Also the Noldens are better on dip beam.
We are not tied to any light manufacturer and if we thought there was any other manufacturer as good as the Noldens we would try them out first on our own vehicles.
So personally I would recommend Noldens over the Speakers 8700. OK the Noldens do cost a bit more then the JW Speaker 8700, however the greater IP rating of 6K9K over IP67 and the greater light output is worth the extra money.
Brendan
Post #279471 4th Nov 2013 7:20pm
Diablo
Thanks. I'm yet to get approval from the other half (that'll be fun), and these are the two I'm looking at as it seems they are fairly similar, usually the Noldens being a bit better in reivews.
Though I do quite like the look of the JWs, which is prob part of the reason for keeping them as an option.
Post #279689 5th Nov 2013 11:35am
Birdy
Is the “other half” buying them then? C’mon man, we are macho Defender-driving, hunting, shooting, off-roading Marlborough Men, we tell the other half: “I pay, I say”!!
Peter (been married three times, wonder why?)
Post #279772 5th Nov 2013 6:33pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Play the safety card......she would'nt want you hurt driving on a cold wet rainy night when for the cost of a couple of lights you would get home all warm and safe Confused BM52
Post #279775 5th Nov 2013 6:40pm
Page 3 of 5 <12345>
