Home > Puma (Tdci) > Clutch exchange
Had your clutch exchanged?
2007, None
10%
 10%  [25]
2007, 1x
11%
 11%  [28]
2007, 2x
4%
 4%  [12]
2007, 3x
0%
 0%  [1]
2007, 4x
0%
 0%  [0]
2007, 5x
0%
 0%  [1]
2008, None
10%
 10%  [26]
2008, 1x
5%
 5%  [13]
2008, 2x
0%
 0%  [2]
2008, 3x
0%
 0%  [1]
2008, 4x
0%
 0%  [1]
2008, 5x
0%
 0%  [0]
2009, None
6%
 6%  [16]
2009, 1x
4%
 4%  [12]
2009, 2x
0%
 0%  [2]
2009, 3x
0%
 0%  [1]
2009, 4x
0%
 0%  [0]
2009, 5x
0%
 0%  [0]
2010, None
9%
 9%  [23]
2010, 1x
6%
 6%  [17]
2010, 2x
0%
 0%  [2]
2010, 3x
0%
 0%  [1]
2010, 4x
0%
 0%  [0]
2010, 5x
0%
 0%  [0]
2011, None
9%
 9%  [23]
2011, 1x
5%
 5%  [14]
2011, 2x
0%
 0%  [0]
2011, 3x
0%
 0%  [1]
2011, 4x
0%
 0%  [0]
2011, 5x
0%
 0%  [0]
2012, None
4%
 4%  [10]
2012, 1x
3%
 3%  [8]
2012, 2x
0%
 0%  [2]
2012, 3x
0%
 0%  [1]
2012, 4x
0%
 0%  [0]
2012, 5x
0%
 0%  [2]
Total Votes: 245
Page 14 of 16 <123 ... 13 141516>
Dieselhead
Mines on 63K 08
Mates is getting on for 90k 09
Both are rattling but keep going Very Happy Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #264397 7th Sep 2013 9:10am
67_6Cyl
France
67_6Cyl wrote:
2007 110 SW, 120,000 kms including lots of towing with 500 to 3300kg trailers, as well as lots of M-way with about 700kgs in the car.
Original clutch, no judder, rattle or other problems observed so far.
Jon
(where is some wood, I have to touch wood NOW!)
(It's all going to go horribly wrong now I have said that all is OK!)
Well, at 160,000 kms the clutch has now died. No warning rattles (or me being too unobservant to notice), or anything. I am pretty pleased with that considering the use that the car gets.
Took the car out of 4th, big judder, and then unable to select any other gear..... home by driving without clutch. Car now with the stealers.
Jon
Post #326952 29th Apr 2014 12:43pm
Dieselhead
Changed mine at 67,500 now
Mates 09 changed at 98,500
Both running mutch better now Thumbs Up Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #327076 29th Apr 2014 9:26pm
martinfiattech
New clutch fitted at 23240 miles, due to rattle at idle speed other wise it was fine, car was just over two years old, they also replaced the gearbox due to faulty third gear syncro.
Since then the pedal feel has been poor, soft at top of pedal and clutch bites an inch off the floor it was not like this before.
The car has been returned to the dealers for this twice "it`s ok we have changed the fluid ect it`s fine
well it`s not its rubbish
I`ve even pressure and vacuum bleaded it myself it`s still poor they did something to the car when they initialy repaired it.
So next week its off to another dealer for more work, my last car lasted 13 years on the original clutch and that's still going even when it was being used to tow a four tonne road compressor, a series three on a twin axle trailer, way over its train weight it never bothered it. Maybe I should have kept the Vectra ? Excuse the spelling I`am better with spanners and wires.
Post #327745 2nd May 2014 9:09am
munch90
yes sounds like air in it to me , try back bleeding only way to get good pedal sometimes
Post #327746 2nd May 2014 9:14am
martinfiattech
Sorry clash in terminology their I call it the pressure bleeder my apprentice calls it back bleeding ( I think it`s a hangover from my Vauxhall days we called it pressure bleeding ).
You mean using a pump action oil can to force fluid back thru the slave cylinder bleed nipple toward the master cylinder, which I keep an oil can for this it`s never seen oil in it`s life it`s always full of brake fluid.
Your right it is often the only way to get a good pedal.
Yes I`ve done that and the resivour fills up quickly Embarassed .
The problem is still there they tell me they have replaced the slave cylinder and a pressure pipe due to leakage but I never saw a leak and lets face it if it had a leak it would have no pedal at all very quickly.
I have placed a hose clamp on the clutch flexy hose lightly pressed the pedal by hand and guess what it was soft and dropped a bit so I think the fault is within the master cylinder itself but they don`t listen / won`t so it`s off elsewhere
Thanks for the advice it is the easiest way to bleed them up . Excuse the spelling I`am better with spanners and wires.
Post #327758 2nd May 2014 9:54am
munch90
never had much luck with vacuum bleeding ,guess you have pressure bleed from the top
even with a dodgy master (normally ) you can still get a good pedal but doesn't last long
to be honest a oil can would not be my choice , ( may draw air as not really very sealed inside when using with a thin fluid ) , I always use a big medical syringe
sorry not knocking your tools just saying
Post #327759 2nd May 2014 10:01am
MK
NOt sure if you have done it already but in my case I just do not press the pedal down to the bottom and release the fluid, but I press the pedal several times very quickly before letting the fluid off. Puma 110" SW
Post #327844 2nd May 2014 2:18pm
Dasher
2015 Defender 110 Puma 2.2 USW Santorini Black
My Dec 2010 110 is in to get the clutch rattles sorted this week - sounds very much like the torque springs and anticipating a new clutch. First vehicle that I've ever owned where the original tyres have outlived the original clutch (and I've had a license 40 years). I still have a couple of weeks warranty left so I may just be lucky, but not holding my breath as getting this done under warranty seems to be a bit hit and miss - we'll see.
Post #332161 19th May 2014 10:50pm
schuee
Evening Dasher
I'm on my 3rd clutch due to the dreaded clutch rattle, all replaced under warranty without any problems from my dealer Smile
Hopefully this is the last one Shocked
Post #332164 19th May 2014 11:00pm
Dasher
Good to know (about the warranty - not the failure). Trying a different dealer from the most local, this one actually appears helpful.
Post #332165 19th May 2014 11:06pm
My clutch is rattlling again now (it's clutch number 3 on a 2007 DC with 145k miles on the clock, and has been in for approx 80k miles) so I have bought an AP driven plate and cover kit to fit, which I understand to be OEM.
I notice that the springs in the new driven plate rattle when the plate is shaken and can be rotated axially by hand. Is this normal on a new plate?
Looking at the driven plate, it seems to me that there is nothing whatsoever to stop the springs falling out once they get a small amount of permanent set on them. It strikes me as a strange and unsatisfactory design - I am not a clutch designer but it seems to me that there are many simple ways in which the design of driven plate could be improved.
Post #332209 20th May 2014 9:06am
MK
Somewhere I read a LR document stating the big springs should rattle when shacking them. I suppose it is designed allowing the springs to rotate so the internal plate does not stress the same spot always.
In other clutches with central dampeners, the springs are hidden behing the cover so they do not fall into the bellhousing. Puma 110" SW
Post #332466 20th May 2014 11:03pm
Naks
yes, I was also surprised when I picked up and shook a brand new clutch plate.
p.o.s design by LR once again... Rolling Eyes --
Post #332480 21st May 2014 6:20am
Dasher
As an update to this, my clutch was replaced under warranty - springs were completely knackered. On road testing the new clutch, the engineer was unhappy with the gearbox - so it now has a new one of those too, also under warranty. 47,000 miles.
I was less fortunate with a corrosion claim. I purchased the Defender as a six months old ex-dem vehicle but insisted, and got, a three year warranty. What I didn't know that only 2.5 years of this was "factory" warranty and the remaining six months was "extended warranty". Extended warranty only covers perforation - they wouldn't cover the crappy bubbling on the coffin posts. Annoying but at least I have a new 'box!
Post #340982 26th Jun 2014 2:01pm
