![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
I too have done mine with Dinitrol over the last week or so. Done exactly the same thing as you pretty mcuh> And agree very very messy especially the under body wax!
![]() Today I did the internals and this is the reason you need safety gear: ![]() Click image to enlarge TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Good job Vizsla, you sound like me painting yours with POR-15
![]() ![]() ![]() Doing SGH's 130 on saturday with a compressor so I'm off to the charity shop to buy a nice double breasted suit, wellies and a trilby that I can throw away when I'm plastered in it ![]() ![]() |
I've met him, don't wear the dress .....
![]() Suppose I ought to give you a call at some point then ![]() |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
You're alright it's Brighton boys you need to worry about ![]() |
Anytime Matt, but should be doing Lukes new 110 the following Sat if delivery dates are sorted
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 ![]() ![]() ![]() |
Delete....
Well my 130 got the Zag & SGH Dinitrol and ACF50 treatment yesterday and what a messy job but totally worth it.
We got through... 4 x 1ltr Cans ML3125 Cavity wax 4 x 500ml Aerosol ML3125 Cavity Wax 11 X 1ltr 4941 Cans Body Wax 9 X 500ml 4941 Aerosol Body Wax 1 X 500ml ACF50 Aerosol 1 X 400ml RC900 Aerosol Rust Converter Oh and I had the throw away my shirt, socks, and trousers afterwards as SWMBO would not let me put them in the washing machine ![]() Zag was white when he arrived I don't know if it was the sun but he was certainly a few shades darker when he left ![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Enjoyed doing it in company for a change SGH
![]() Found a great way of getting Dinitrol out of your hair, scrub with a hair brush with two washes of fairy liquid in very hot water, either that or go get yourself a number one! Fairy worked well on face and arms with a pan scrub also ![]() Think SGH's 130 has got to be one of the best in the country, high individual spec and still less than 3000 miles, rust free of course ![]() SGH sprayed the rear crossmember with Dinitrol rust convertor which sets like a varnish. We are going to see how well it stands up to the job as it could be the perfect solution. I put some on my yacht a year ago as a test and it is still shiny and hard although in a locker out of the sun... |
You forgot to try the Dinirol hand cleaner that works a treat to get it off.
As for getting out of hair ![]() ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3660 ![]() ![]() ![]() |
white spirit gets it off and is great for any overspray, but then you need to get that off DEFENDER 90 TDCI XS,
I checked the condition of my ICE last weekend, the dinitrol is holding up well... (TBH since the arctic it's not seem much use)
Seeing the thread on the side steps, i'm going to pop the end caps off and spray dinitrol inside them. I popped the rear step off to check for any corrosion where it's mounted and remembered i had sprayed dinitrol on the surfaces already. |
Shep Member Since: 02 Sep 2013 Location: Pwhelli Posts: 95 ![]() ![]() |
Does anybody ever use Owatrol on the chassis rusty bits, it gets a lot of use in the boat world, paint straight on non flakey rust, leave to go tacky, paint again, job done. Dries to a hard varnish finish.
I'm also a big fan of ACF 50 and it's sister 'Corrosion Block' anywhere you can see ACF50, anywhere you can't corrosion block. A man with no boat is a prisoner |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
There is a 10mm drain hole on each end you can fit the spraying tool up to save taking off the ends of the steps. I did part 1 of my dinitrol today. 2 litres of ML wax into the main chassis only and it was easier than I thought. Was concerned that I wasn't coating it properly as I used so little but not much ran, ran a test on a bucket I had with a 1 second spray and it covered all of the inside really well. The sealey wax gun really atomises the wax well, did it in sections. Adjusted the gun so that it wasn't over delivering wax. 2 litres in about 250ml ran out ![]() So done with minimal mess. Will do the bulkhead, doors, 4941 underside next weekend when I have more time. |
Mr Didot Member Since: 05 Oct 2013 Location: West Sussex Posts: 11 ![]() ![]() ![]() |
This is my first post on Defender2.net
My new XS90 arrived last week ![]() Should I be giving her a dose of Dinitrol from new? There are some holes on the door rubber seals - is this part of the classic Land Rover design? https://www.defender2.net/gallery/displayi...&pos=1 Also the wire loom is exposed under the wheel arch. This is quite different from my old 2.5NA landy. Is this common on all new Tdci station wagons? https://www.defender2.net/gallery/albums/u...020184.jpg Any thoughts would be welocme? |
