Home > Wheels & Tyres > Advice on new boots
Page 3 of 9 <123456789>
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
nice one, thanks chap
Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #26254 8th Mar 2010 4:50pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Some officious garages won't fit them to 7 x 16, so best ask before hand Original Member Pie n Pea Club.
110 HCPU Tipper
Post #26255 8th Mar 2010 4:52pm
Glynparry25
265/75 will go onto a 7" rim (Boost) with no problems. But you have to realise that they will not sit as tall as the origional 235/85s
285/75s have been put onto 7" rims even though it isn't recomended....only thing I would be carefull of is if your insurance company or police went down that road after an accident (they are clamping down on LRs after the Gresham incident).
Spacers- anything bigger than the 235/85s on standard offset and you will need them....but if you are getting aftermarket wheels they will more than likely already have a 25-30mm offset so no spacers needed.
I run 285/75/16 on Tx rims which have a 30mm offset and on standard suspension and on full axle twister the rears just kiss the arches. I have had no problems with them- considering 1" extended stops to counteract this but since no damage is caused I will probably never get round to it.
Glyn :sheep:
Post #26256 8th Mar 2010 4:56pm
MuddyMarky
Fitting shouldn't be a problem, a good friend owns a recovery garage with a tyre centre, so shouldn't get any advice unless asked for.
Smile
No-one seems to know of/mentioned any problems after having 285's fitted to 7's though, have they? They're not going to get too much abuse anyway.
*edit - Cheers, Glyn, I'm considering the 30mm spacer option aswell. Waiting to hear about some at the moment. Any particular make I should look out for, or any particular material, etc? Mark
2011 110 XS DC
Stornoway Grey
Post #26257 8th Mar 2010 4:59pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Try and get the spacers with the center wheel alignment on them as people have had issues with wheel vibration as the wheel dos not sit right Thumbs Up
Hub Centric Design
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #26258 8th Mar 2010 5:08pm
MuddyMarky
Yes mate, I remember that 'hubcentric' (I think its called) when I had a set for an Audi some time ago... just wondered if anyone had any recommendations for makes, etc?
Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #26260 8th Mar 2010 5:20pm
fekete
These are good Rakeway engineering
http://www.rakeway.co.uk/Land%20Rover.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #26264 8th Mar 2010 5:33pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Isn't discocuzzy trying to sell a set of spacers at the moment? Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #26265 8th Mar 2010 5:38pm
discocuzzy
Muddy mark, thanks for the Pm, my 30mm spacers for sale are top quality with the hubcentric design Thumbs Up
I have wound my lock stops right in and you get a great turning circle, they do rub slightly on full lock but nothing to worry about, i just backed off a touch when required.
I have run 285s on boosts for ages and never had a problem. You cannot teach stupid people to do clever things
Post #26270 8th Mar 2010 6:01pm
MuddyMarky
You have a PM mate
Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #26275 8th Mar 2010 6:47pm
TACK
Just to confuse matter and opinions, spoke to silverline today was set on what i was going to get and i was advised i would need a lift the vehicle to run 285 as these would foul Rolling Eyes He has advised go 265 then no lift and no spacers using modulars Banging Head
I am getting confused. I know if I use the boosts I need spacers (thanx glyn) but thought the 285 on modulars would be fine Question Exclamation
Post #26296 8th Mar 2010 9:20pm
Glynparry25
I think they are being extra safe. I guess it will depend on the tyres too. Ifit comes to the worst just sticking a set of extended bump stops will prevent fouling......but jut look around the site and you will see many running 285s with no problems and even 33x12.5 which are even bigger!!
Getting 265s and then getting a lift followed by 285s and you will end up being Steve's mini-me
Glyn Sheep
Post #26298 8th Mar 2010 9:24pm
discocuzzy
You dont need spacers on modulars Tony, they have a big off set as standard...i.e the wheels are further out from the hubs than boosts....you dont need a lift either as you have heavy duty springs on the back of a utility Thumbs Up
Glynne is right, ive spent a bloody fortune messin about...get the 285s on modulars and see how you get on..you may only have a slight chance of fouling on maximum articulation which wont be that often.
If you do then a set of springs is a lot cheaper than another set of tyres Shocked You cannot teach stupid people to do clever things
Post #26305 8th Mar 2010 9:40pm
fekete
Same as Discocuzzy you will have no problems with 285 on modulars no spacers no lift Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #26307 8th Mar 2010 9:47pm
TACK
Thanks guys, thats what I needed, dont want to do the money then find out i made the wrong decision Thumbs Up Thumbs Up
Going to go 285 cooper ST or STT on black modulars Mr. Green
Post #26310 8th Mar 2010 9:59pm
