Home > In Car Electronics > The definitive Defender ICE thread
Page 37 of 71 <123 ... 363738 ... 697071>
Making a push to get hold of the Tweeters what I've been banging on about for months. Rolling Eyes Shall get them ordered hopefully soon. Smile TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #250176 9th Jul 2013 8:48am
AlexPuma42
had a good read through this thread and a lot of the builds are just a dream for me
I drive a Puma Hard Top which is required for work so i cannot fit a sub into the back as it takes away vital loadspace
anyhoo im now going to head in the active sub direction with it being mounted on the bulkhead behind the seats.
The whole reason iv started the ball rolling with fitting an install is because my head unit has decided it doesnt want to play ball and not working - so in the process of changing this i might aswell do my speakers
i want to use these speakers off of just Kenwood but will i need to use spacers/adaptors?
- http://www.justkenwood.co.uk/car-audio.aspx/kfc-s1094-speakers
Any help is muchly appreciated
Post #252092 18th Jul 2013 8:57am
barbel jim
Steve's your man for kenwood, But yes they will fit ok. Only 43mm deep so should fit straight in no spacers required. I fitted some 70mm deep in a puma a while back. When I have fitted active subs to the bulkhead, I mounted on a board fist , which I covered with cloth 1 side and rubber on the back. This will help eliminate rattles created by the active being up against the bulkhead Thumbs Up
Post #252143 18th Jul 2013 12:03pm
I mirror what Jim say's above. Check out my Gallery for some ideas of mounting an active sub. What one were you thinking of looking at?
Also speaker wise they will indeed fit perfectly I have the exact same one's only the previous grille model but the power is the same. You can either mount in the existing holes but the speakers won't be straight but at an angle or if you prefer as I did you can drill new holes. All fixings are supplied too.
If you want powerful bass though you will need to go bigger but that entails plenty more work. These are very good though and top sound quality and your sub will produce plenty off bass for you.
Gimme a shout on here or via PM if you want to chat. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #252198 18th Jul 2013 3:52pm
Oh and just read the end of Jim's post. On my HU's control module mounting board I used adhesive foam strip. Not just to stop rattles but stops rubbing (ohhh er Shocked ) but also stops muck rusish and most dust getting behind there.
I do have some spare if anyone requires some... TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #252199 18th Jul 2013 3:54pm
gambit
I have a TD5 90. Earlier in this thread there was mention of a 1.5 DIN head unit that might be an option to allow you to get rid of the plastic insert.
Can't find one of those, so is another option to make the opening bigger with a dremmel or similar and then fit a double DIN?
I wonder if it is straightforward or not, given the retaining socket for the rear of the unit?
I am thinking of getting a replacement head unit to my Kenwood CD player too, nothing wrong with the unit, but am thinking of a reversing camera?
Are there other options? I was shown a mirror gadget, but that looked kind of ugly and too big to be honet.
Post #252290 18th Jul 2013 9:38pm
Never known of a 1.5DIN unit. If you wanted to go for 2 DIN just check you have room and then you can cut out the extra size. Simply fit a 2 DIN cage and that's done. I wouldn't worry about the rear mounting too much you can buy universal brackets to fit the rear if required and the wiring shouldn't be a problem. If the plugs are ISO then it's plug and play if not there are plenty of adaptors available. You can indeed have a rear view cam linked to the HU but it won't be cheap. All this is possible on a single DIN flip out like mine though without all the hastle of fitting and cutting. But I assume you don't want that?... TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #252293 18th Jul 2013 9:45pm
gambit
Thanks for the quick reply and thoughts around fitting a double DIN. I would be fine with the standard DIN and a flipout screen. The problem is, I find the little plastic surround a bit loose, always has ben. This may be fixable with a new part. As I recall the wires holding the surround in place do seem a bit oddly shaped, but don't know if that is normal.
The surround is the only reason I was thinking of going up from a single DIN.
I have been toying with the idea of a flipout screen for ages, long before getting my Defender really. If I was to do the upgrade over a number of months, spread the expense out, is the likely to be a compatibility issue. I mean, get the head unit now, camera in a couple of so months...?
Especially if I bought end of range to get the best deal Smile
Post #252318 19th Jul 2013 3:27am
A single DIN cage would sort that out by locking it in place. Wink Getting items in stages is not a problem I do that a lot. Just so long as you don't leave it years before buying each item you should be fine. And even if there is a newer option of an item often or not it's backwards compatible AND with improvements sometimes. A Kenwood reversing camera for example is around £130. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #252357 19th Jul 2013 8:26am
AlexPuma42
thanks for all the fast replies you sound like a man of much knowledge when it comes to a system lol
Cheers for that i think i will mount them on an angle for now bit wary of my DIY skills haha - Iv not got as frar as deciding what type of sub/Watt's etc yet but wont be massive as its a works van so at times its not only me driving have to look after the older generation i work with lol
cheers once its all arrived i will eye it all up and possibly send a PM over
Muchly appreciated
Alex
Post #252364 19th Jul 2013 8:38am
AlexPuma42
Muchly appreciated
Alex
Post #252365 19th Jul 2013 8:38am
No problem at all. Drop me a PM anytime. Thumbs Up I would offer to give a hand if need be but I think Manchester is a little too far don't you. Surprised Shocked Laughing TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #252370 19th Jul 2013 8:57am
AlexPuma42
Muchly appreciated
Alex
Post #252374 19th Jul 2013 9:06am
gambit
Forgive my silly question - is this the same thing that comes with the head unit? Or something else?
edited: just done a quick google search. I have a DIN cage already. To be fair, it does stop the rattling about and only very occassionally does the plastic surround seem to protrude a little... Perhaps I haven't done such a good job of moving all the wires out the way when pushing the unit in to the cage?
As I recall there were a whole heap of wires I just didn't use
Post #252499 19th Jul 2013 8:35pm
Yep make sure your cables are out to the side of the HU or any direction really away from preventing the HU from sliding all the way in properly. That and you don't want trapped wires full stop. You should see mine down the back there on my Puma the whole of the back of my dash is wires pretty much. Laughing Shocked Laughing TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #252511 19th Jul 2013 10:17pm
