Home > In Car Electronics > Focal Speaker Upgrade |
ethanicus Member Since: 11 Jan 2013 Location: Surrey Posts: 94 |
Hi All,
After a week of ownership I’m loving the D90. However the factory speakers are C**P. As I’m a fan of Focal I decided to fit a set of K2 KRS 100 in the front and PC100 in the rear. What a massive improvement over the standard setup. I know speakers have been done to death put I thought I would share some pics to help those that are thinking about doing it. I wanted a factory look so kept the standard 4” setup. Fronts Click image to enlarge Click image to enlarge Rears Click image to enlarge More pics in the my gallery. https://www.defender2.net/gallery/thumbnails.php?album=1076 Next stop active sub, to cover the low range. |
28th Jan 2013 8:35pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
good choice CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
28th Jan 2013 8:38pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
are they a direct plug and play replacement or is additional wiring needed?
28th Jan 2013 8:39pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 |
Best driven off an amplifier. I've done the same upgrade, but with 13cm polyglass VRS speakers, and a Rockford Punch amp.
28th Jan 2013 8:46pm |
I will in the future, I just need a quick win to get me by, |
28th Jan 2013 8:47pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
I have same front upgrade ready to fit and bought iBus 2.1 under seat sub to add to the system.
Fitted sub today and decided to run the cables under vehicle rather than inside to make a neater install. Where did you fit the crossovers as not much room on offside Simon |
28th Jan 2013 8:48pm |
Just inside the dash againt the section by the door. You need to clean well as its a bit dusty inside.
I think imgoing for a Alpne SWE-1200 as a friend has one and it seems to work well with the focals. How did you run the sub cable from the head unit? |
28th Jan 2013 8:53pm |
iBus 2.1 is ISO connection comes with a 3mtr lead. |
28th Jan 2013 8:55pm |
SimonR Member Since: 28 Jun 2012 Location: Horsham, West Sussex Posts: 74 |
I have an Alpine sub, intended to fit under lesser car seats which have more room. Mine is under the rear seat and has made a tremendous difference to the sound. I have Alpines in the dash too but they made less of a difference - still good though.
Si |
28th Jan 2013 9:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20558 |
Neat. How did you gain access to position the cross overs again? Did you pull the dash back a bit or go though the speaker holes? KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
28th Jan 2013 9:05pm |
Thanks All installed via the speaker hole. No need to disturb the dash. All I did was cable tie the old tweeter cables to stop vibrating. |
28th Jan 2013 9:09pm |
That's a good idea with the cable ties. On a rough road it can be highly annoying cables vibrating I have a heck of a lot behind there so I know.
How did you get on on the off side with the heater vent tubing in the way? Or was there enough room around that? KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
28th Jan 2013 9:38pm |
exactly what i did, i insulated mine and used double back foam to stick it to the inside of the dash up through the speaker hole CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
28th Jan 2013 9:39pm |
Great minds....
28th Jan 2013 9:46pm |
